Wet1 said:
Man, you look like you're just asking to take a potentially dangerous shot to the crown jewels (and or major arteries) by sitting like that while splitting! I'm sure you could go many years working like that and not have an accident (I'm sure Dennis will pipe up here), but man does that look at least somewhat dangerous to me... Not to mention it looks like a lot of work getting up and down, plus moving logs to that low position (moving the splitter seems like it would be even more of a PITA!) I've tried it few times and no thank you! Then again, looking at the design of the splitter, it looks like it would be too low in the horizontal position to comfortably work, not to mention it seems to lack a production table... so maybe you are using it in the easiest manor based on its design. Even so, it still looks dangerous to me to be sitting like that. Please be careful!
Wet1 and to others. I know what the manual says on how you should split and perhaps to you it does look dangerous, especially for the family jewels. Believe me or not, it is not dangerous at all.
Those who have thought it dangerous are the ones who worry because sometimes with some wood a split can go flying. However, I have never seen a piece go flying backwards; they always fly sideways. So all you have to be careful with is that right leg. Also, the only time I've had a split fly sideways was when I was making some kindling (before I learned the best way). Now it has been a long, long time; many, many moons since I've had any split fly.
Now for the getting up and down. You do not have to get up and down very much at all. You can split a long time just by reaching out with the left hand and then rolling the log to you. Yes, I do move the splitter when I run out of wood and moving the splitter a few feet is much easier than lifting every piece of wood up onto the splitter in a horizontal position. Also, my "production table" is Mother Earth.
No, I don't wear a cup! lol As stated, it is not needed.
Splitting wood as I do is the easiest way to do it. I have to do it the easiest way possible due to some physical problems and this way is simple, easy and quick. If someone wants to speed things up more, have a helper keep some logs right next to you and you can sit and split for hours or until you run out of gas.
