Harman Accentra distribution blower shuts off
9
Yardley, PA
We have a somewhat drafty living room where the 5 year old insert is in the fireplace. The distribution blower shuts off periodically and we can't seem to get the room as hot as we used to. I have done all the maintenance and cleaning. All original parts still. I have cleaned the ESP probe previously. I want to be able to set the stove so that the distribution blower never shuts off and maxes out the heat to the highest possible extent.
Currently...
Temp: 7/90 degrees
Feed: 5
Igniter: Auto
Mode: Room Temp - High
Thermometer is about 6 feet away from stove and the actual room temp gauged by our central heat thermostat on opposite side of the room is only about 67 degrees when it is 40 outside today. When it is colder outside the room may only get to low 60's. In the past, we have been able to get the room to the low 70's.
I'm trying to think all about this logically, but without having full knowledge of all parts.
The igniter does sometimes seem to lag a bit when lighting in the morning, but I don't think that would cause a problem with the heat output once it gets going. Although the blower operation is intermittent, the blower doesn't seem to make noises like it is going bad, but I'm not sure. My logic is telling me it might be the instructions from the system telling the blower to shut off.
Our budget is tight, so I don't want to spend money on parts unless it is really necessary. I have done a lot with computers and hardware, so I feel I could change almost any parts without paying a dealer. In speaking with our dealer, they told us they would need to take the stove back to their shop if the blower or system board needs replacing...I don't like this answer...do you feel it has to be this way? (I feel like they may be trying to ramp up the labor charges.)
What are the best settings to keep the blower and heat output high?
If I can't get the distribution blower to stay on constantly, what parts would I consider replacing?
Where are the best parts prices/reputable dealer online or to call to order?
Thanks in advance!
My blower did that on a 5 day old stove. Bad ESP, in my case. Actually, the blower was highly erratic with its on/off cycles, sometimes cycling 3 times in 10 seconds. DDM was put on the stove and the ESP reading was ALL over the place.
I'm sure others will chime in.
www.woodmanspartsplus.com has very good prices on ESP's IF that's what it ends up being.
Is your dealer a small operation? Never heard of one not making house calls, but maybe that's just my area.
Try running the stove on "Stove Temp" high. The room blower will never shut off. Put the feed rate at "3". Make sure you clean the ESP probe and clean the baffles clean , this will allow more heat from them instead of them being insulated with ash build up. Let us know how you do.
It would be helpful to know if there is Voltage at the motor when it turns off.
Blower motors are often thermally protected. What that means is that if the windings overheat a thermal switch in the motor stops the motor even though power is available at the leads. This will happen if the motor's vents are clogged with dust, lint or animal hair.
Reactions: heat seeker
Thanks for the info so far...
P38X2, Our dealer is a small operation, they installed it and they will come out to service it.
MSmith66, By "baffles" do you mean the heat exchanger panels? I cleaned the ESP which really wasn't dirty as I cleaned it near end of last season. I cleaned everything else again, which also wasn't too bad because I cleaned it all last week trying to resolve this issue. Also tried Stove Temp high and feed rate of 3 and it still cycles off the blower. Do you think I need a new ESP? I can get one online rush shipped (they're calling for 4-6" of snow tomorrow with a cold week coming) I feel like I should order it fast.
Harvey Schneider, I vacuumed everywhere else I could and I didn't see clogged vents or lint and we have no animals.
You mentioned not wanting to spend money buying parts that weren't necessary, but you could always look at it as the ESP will need replacing at some point in the future, assuming you're not gonna get rid of the stove. The price isn't bad at all, IMO, but imagine the next day shipping isn't cheap. You may be able to just get one from your dealer at that point.
I'm not suggesting your ESP has failed, but that COULD be the problem. It could be a bad pot, also inexpensive IF you can replace it on your own, which I bet you could with your experience in electronics. Could be a bad board, which is not cheap, but easy to swap out, at least on a free standing unit.
Found an ESP at a dealer 20 miles away...swapped it out for $69, but it doesn't seem to be the problem...I had to start somewhere. Now I'm thinking I need a new board (which was my original gut feeling) Any thoughts?
replaced ESP...replaced board...no change in problem.
Solution - cleaned the distribution blower fan.
If you've never done this before, it probably needs cleaning. It is underneath the unit. I pulled the stove out and (with help) laid it on it's side onto some couch cushions and an old blanket. I found a massive clot of lint, hair, debris, wrapped into the intake, which undoubtedly would not let it run properly. Afterwards, the stove ran like new.
Whoa, that thing looks like a small intestine!
Most small motors are "thermally protected". That means that they often have a thermal switch in them that shuts off the power if they get too hot. Given enough time to cool down they restart. With the intake blocked by whatever that is, the motor cannot cool itself.
Blower cleaning has to be a part of annual maintenance otherwise, efficiency of the heat exchanger drops off and your heat goes out the vent.
You guys check out the dates of the OPs?:)
Yup. The OP was the last post in January and then he picked up where he left off by posting his solution last night. I don't see any issue.....other than he didn't clean his distribution blower for 5 years....yikes!!
The OP updated his thread. Great to get the feedback, thanks OP!
Ah, sorry. Didn't see that the intestine pic was the OP.;em
