harman accentra insert dist blower underneath is fried ...
johnchap Posted By johnchap, Mar 17, 2013 at 9:45 PM
  1. johnchap
    johnchap
    Member 2.
    NULL
    Oct 15, 2008
    51
    1
    Loc:
    North Central CT and Southern VT
    hey I am wondering about replacing my distribution blower --- one site I found said I will have to redo soem wiring ...as they stopped making a threee speed blower .... my accentra insert is 2006 model .... any advice , tips would be great ..this is below the stove so I will need to tip it ? or does this drop rightout (too easy right?) oem price 290 was about as best I can gather .... cost of pellet life
    any one replace one ?? tips ?? advice ??? warnings ? blessings?? :) thanks
    my[​IMG]
  2. MSmith66
    MSmith66
    Feeling the Heat 2.
    NULL
    Feb 5, 2008
    404
    26
    Loc:
    Central NY
    I just replaced one the other day, you will have to tip the stove forward. The motor shown is the one, you will have to remove the motor from the mount by taking off the 3 nuts on each arm. You will not need that large black mount. There are 4 wires to the motor its self, you will two wire connectors for the black and white wires. The red and blue wires will need to have a butt connector each. Very simple job, it takes longer to pull the stove out, tip the stove, and push back in than it does to replace the fan.
  3. johnchap
    johnchap
    Member 2.
    NULL
    Oct 15, 2008
    51
    1
    Loc:
    thanks! makes it sound very doable .... so it is easier than doing pistions and rings :)
  4. MSmith66
    MSmith66
    Feeling the Heat 2.
    NULL
    Feb 5, 2008
    404
    26
    Loc:
    Central NY
  5. johnchap
    johnchap
    Member 2.
    NULL
    Oct 15, 2008
    51
    1
    Loc:
    local harman dealer has one for 271.00 better than internet prices .... oh joy for the weekend
    thanks
  6. smwilliamson
    smwilliamson
    Minister of Fire 2.
    NULL
    Dec 28, 2009
    4,501
    782
    Loc:
    Southcoast, MA
    Amazon has them $93
  7. minnow
    minnow
    Member 2.
    NULL
    Oct 27, 2006
    102
    6
    Loc:
    Upstate New York
    Are you saying that the red and blue wires are spliced together and only the black and white wires are actually connected to the stove wiring ? I have the same stove (2005) and it sounds like my distribution motor is starting to go as well.
    Thanks
  8. MSmith66
    MSmith66
    Feeling the Heat 2.
    NULL
    Feb 5, 2008
    404
    26
    Loc:
    Central NY
    The red wire should have a butt connecter on it and the blue wire should also have a butt connecter on it (2 connecters). The white and black wires should have a spade connecter each to plug into the stove wire harness. Then tape all 4 wires together and snake them into the hole in the bottom of the stove. Should come out just to the side of the auger motor, control panel side.
  9. johnchap
    johnchap
    Member 2.
    NULL
    Oct 15, 2008
    51
    1
    Loc:
    blower went in easy - two wires on motor ... butt connector - easy feed - I tend to snake a firm wire thru and tape then pull back thru .. works with general electric feeding in tight spaces of home as well ......
  10. MSmith66
    MSmith66
    Feeling the Heat 2.
    NULL
    Feb 5, 2008
    404
    26
    Loc:
    Central NY
    :)) Nice!!
