branchburner
That's what I'd want, too... it's possible it just seems the flue is warmer because so much heat is getting kicked off the back of the stove. We'll see what the numbers say.
stanleyjohn said:I think that when the AB is activated the stove temp does drop alittle!in my case it seems to be the case.The afterburner was designed to burn wood clean!(not to increase the stove top temp).The big heat up with the AB running will be in the AB chamber itself with alot of that heat going up the flue.
FIREFIGHTER29 said:stanleyjohn said:I think that when the AB is activated the stove temp does drop alittle!in my case it seems to be the case.The afterburner was designed to burn wood clean!(not to increase the stove top temp).The big heat up with the AB running will be in the AB chamber itself with alot of that heat going up the flue.
Could not have said it better myself. Yes it may burn hotter in the AB but it still will not produce the amount of BTUs the fire box will with a load of wood burning full throttle.
uptrapper said:Looking at those facts I would have to say my stove puts out more BTU's/ hour with the ab on. My stove pipe temps drop more than the stove top after putting it in ab, which would lead me to belive less heat is going up the pipe. Further more I sit right in front of the stove when I am getting it up to temp, and about 5 seconds after the bypass damper is closed I get a very noticable increase in temp on my face.
trump said:Im sure most of the heat from the AB is transfered to the room as the air channel in the back of the stove that exits out the top of the stove blowing forward surrounds the AB chamber. While most of the BOttom part of the AB is insulated refractoy material to contain the High temps. the top half is bare steel, the blower pushes air through this air channel so i would say the blower is more effective when the AB is engaged than otherwise.
stanleyjohn said:I also have noticed that my afterburner runs very well with stove top temps around 350 deg.My door glass does get some brownish tint mainly on the bottom sides.This may be because of the low stove temp.I did get the stove hotter later when i put in a few more splits to a peak in the high 500s..So it seems to me that the afterburner will run fine with temps in the 300s!this suits me fine because the stove heat output is plentyful with the fan running.I have noticed that when a good amount of the wood goes into the coal stage then the afterburn shuts down.At this stage of the burn its likely not needed anymore because there is very little smoke left to burn.
trump said:stanleyjohn said:I also have noticed that my afterburner runs very well with stove top temps around 350 deg.My door glass does get some brownish tint mainly on the bottom sides.This may be because of the low stove temp.I did get the stove hotter later when i put in a few more splits to a peak in the high 500s..So it seems to me that the afterburner will run fine with temps in the 300s!this suits me fine because the stove heat output is plentyful with the fan running.I have noticed that when a good amount of the wood goes into the coal stage then the afterburn shuts down.At this stage of the burn its likely not needed anymore because there is very little smoke left to burn.
How do you know when your AB shuts down? can you see it burning or is it just that you do not hear the rushing air sound.
FIREFIGHTER29 said:trump said:stanleyjohn said:I also have noticed that my afterburner runs very well with stove top temps around 350 deg.My door glass does get some brownish tint mainly on the bottom sides.This may be because of the low stove temp.I did get the stove hotter later when i put in a few more splits to a peak in the high 500s..So it seems to me that the afterburner will run fine with temps in the 300s!this suits me fine because the stove heat output is plentyful with the fan running.I have noticed that when a good amount of the wood goes into the coal stage then the afterburn shuts down.At this stage of the burn its likely not needed anymore because there is very little smoke left to burn.
Sometimes I can hear my AB operating and sometimes I cant. So I do not completely rely on that alone to tell if it stalled or is even operating. I pay attention to the stove temps at the connector pipe and stove top. And a quick check of the top of the chimney outside will tell the tail. And if you do have a view of the AB chamber opening you can see if it is operating. Sometimes the wood will block the view.
trump said:FIREFIGHTER29 said:trump said:stanleyjohn said:I also have noticed that my afterburner runs very well with stove top temps around 350 deg.My door glass does get some brownish tint mainly on the bottom sides.This may be because of the low stove temp.I did get the stove hotter later when i put in a few more splits to a peak in the high 500s..So it seems to me that the afterburner will run fine with temps in the 300s!this suits me fine because the stove heat output is plentyful with the fan running.I have noticed that when a good amount of the wood goes into the coal stage then the afterburn shuts down.At this stage of the burn its likely not needed anymore because there is very little smoke left to burn.
What are your Flue pipe temps when at various stages of startup and after AB is started? I only did a few fires so far ,Im waiting for colder weather so I don.t have to use the lowest setting all the time. My Coal stoker is good when only a litttle heat is needed and it does my hot water too. I know on my last full load of wood the AB did not light as it creosoted up the stove and flue pipe and chimney pretty bad.Im sure i engaged the AB way too soon.So when temps get 40 day and 25-30 night ill give it another try and as i can rarely see the AF (Ill try to stack the wood as to make a tunnel to observe)im going to go by stovetop and flue temps as when to engage the AF. Ill try 550 stove top so at thet temp what would the Flue pipe read before and after engaging the AB?
