    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. jeepinman9 Member
    Central Pa
    I need to replace two of the fire bricks in my Harman TL300. The dealer says harman specs a brick for earlier models that cost $45 each andone for later models for $15 each. Both are 6x12x1.5 inches, my stove is an early model which requires the expensive bricks (just my luck). Does anyone know that the difference is between the two bricks? Will it hurt my stove to use the cheaper bricks if they are indeed the same size? Does anone know of a place online to purchace harman parts which may be cheaper than my local dealer?
    #1
    Helpful Sponsor Ads!
  2. BobUrban Minister of Fire
    Central Michigan
    Wow - thot is pricy for sure? I just picked up a couple bricks at TSC for 3$ a piece but they are not as big as your stove requires. I am not sure of the set-up but would guess you could use any fire brick available. The bricks from TSC are 9x4.5x1.5 I would think you could buy a few and cut them to fit although others with more knowledge may have reason to disagree. Could even use stove cement to glue them together. Cement may not last as long as the bricks but once in place and ashed up a bit I am thinking the insulation should not be compromised much at all. The cuts would be no different than the gaps between the existing bricks.
  3. MishMouse Minister of Fire
    Verndale, MN
    I also used stove cement on my bricks until I could buy replacements, I think my bricks also costed in the $45 range.
  4. begreen Super Moderator
    South Puget Sound, WA
    Wow, sounds like they're gold plated. Put in those logs gently.
  5. raybonz Minister of Fire
    Carver, MA.
    Man those bricks are insanely expensive! I would be improvising if it was my stove using standard firebrick and a little ingenuity I am sure you could make your own larger brick..
    Ray
  6. jeepinman9 Member
    Central Pa
    Anyone else?
  7. DAKSY Super Moderator
    I'd go to a local masonry supply store or a block manufacturer & see if they have any or if they can get some for you. Harman buys those fire bricks somewhere...
  8. MishMouse Minister of Fire
    Verndale, MN
    I got home yesterday and was about to add more wood and I noticed that the HARMAN brick was broken off and laying in the AB chamber. Wife must have got a little to pushy adding wood before she left. Since the brick was broken horizontially just above the word HARMAN I will need to replace it. I called the dealer and he said it is going to be $70. Which is a deal, according to his price list the price on the brick next time will be over $100.
