    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. wood-fan-atic New Member
    Long Island, NY
    I see ads for these new manufactured firewood blocks everywhere. They are made from hardwood waste and have no glue/binders. I dont think I'd ever 'switch' to using them full time( I hate paying $$ for something that I can get for "sweat equity'). But I'm painfully curious if they burn as hot/long/clean as advertised. Has anybody used them? The ones Ive been seeing on my local CL are called 'Envi 8' , but they are made by several co.'s. Anyone have a report?
    #1
    Helpful Sponsor Ads!
  2. SKIN052 Minister of Fire
    I have not used those particular ones however last year I used some very similar since my wood was not seasoned. They burn very well, nice and hot, long but no coals created. They just turn to ash.
  3. backpack09 Minister of Fire
    Whitman, Mass
    I burned the original Envi blocks back 3 years ago when I ran out of wood midseason.
    They burn great, but they took a decent kindling fire to get them started. I would definitely burn them again in a pinch.
  4. hoof120 New Member
    Long Island
    I started to mix them with the green firewood I was told was seasoned. I use them full time now. Seasoned firewood on Long Island is impossible to find. There are just to many scams. I was going to swap out my wood stove for a pellet stove before I found them. The cost of the blocks is the same as a ton of pellets. I manages to save over $3000 buy using these and not swapping stoves.
    Envi 8 blocks are made by enviblocks. No other company makes the Envi 8 block. Im not sure if you thought several companies made Envi 8 blocks.
    The envi block is 6 to 7 lbs per block. The envi 8 blocks are 3 to 4 lbs per block. They are all hard wood.
    Other blocks I tried were Bio Bricks, Liberty Bricks and Heat Smart Bricks. These manufactures have soft wood or use byproducts.
    They burn good. The BTU value on these are about 5500. The envi and envi 8 blocks are over 8000 BTUs. I did the math one drunk night. I came up with about 3 cents per BTU.
    Clean up on the blocks is great if you using a vacume. No nails and coals clocking my vacume. I burn 2 tons a year.
    I love them. Hope this helps.
  5. spirilis Feeling the Heat
    New Market, MD
    where did you get the 5500 figure from and the 8000 figure for envi's?
  6. hoof120 New Member
    Long Island
    You can find the information on the websites,
    heat smart bricks: http://www.applingpellets.com/bricks.html
    One ton of HeatSmart bricks has approximately the same BTU value as a full cord (±5500 lbs.) of seasoned red oak firewood.
    Envi Blocks: http://enviblocks.com/
    Technical Information
    BTU PER POUND - 8000+/-
    MOISTURE - Less Than 6%
    ASH - Less than .5%
    I coulnt find the btu on the bio bricks. The do have a data chart of the bio brick compared to cordwood.
    http://www.biopellet.net/data.html
  7. hoof120 New Member
    Long Island
    I found the envi blocks lasted longer than the other bricks on a per lbs test.
    I purchsed a few bricks from each company. I cut some of them to make sure I had the same weight for each company.
    I forgot to add the wood brick fuel as one that I burned. They have a higher btu rating than the heat smart bricks but burned faster than the enviblocks.
  8. spirilis Feeling the Heat
    New Market, MD
    ah k I think they're saying that a cord of red oak is around 5500 pounds total, or 2.75 tons.
    8000 BTU/pound give or take sounds about right for very dry firewood. The stuff I burn (woodbrickfuel, similar to biobricks) the mfr. claims it's around 7500 btu/lb give or take partly because that's the given BTU value by some formula for wood at 6-9% moisture level and I believe they confirmed it by lab experimentation too.
    most of those products using extremely dry wood waste as their source probably clock in around that ballpark, but to say 1 ton of that stuff is equal to 2.75 tons of seasoned red oak is flat out BS, IMO. I never buy that argument one bit, as 1 ton would be around 15-16 million BTUs. that's similar to a cord of softwood, not hardwood. The moisture levels are different no doubt but I doubt that's significant enough to close the gap, the only thing that could close the gap a little further is the ability for compressed sawdust bricks to burn complete (into nothing but ash) instead of leaving some unburned charcoal behind, but those coals are perfectly usable the next time you fire up the stove too.
    what sells these products IMO is the convenience factor, which is why I buy them--they stack wonderfully in very little space in the garage (they're very, very dense--much denser than oak) and don't track in fungus or bugs and I never have to wonder if they're fully seasoned. I don't have a good place on my property for seasoning cordwood so this works well for me.
  9. spirilis Feeling the Heat
    New Market, MD
    that is pretty interesting. I have a sneaky suspicion that some are "compressed" tighter than others (and I'm pretty sure that will affect burn rate/burn time). the woodbrickfuel makes coherent bricks but they seem like they could've been compressed tighter when I inspect them. they don't fall apart when I handle them, but they seem to expand and become soft rather quickly in the firebox. I haven't compared them to other products though, maybe I should.
  10. hoof120 New Member
    Long Island
    I spoke with a guy that had blocks that fell apart on him. I’m wondering if they are the wood brick fuel from what you’re describing.
  11. spirilis Feeling the Heat
    New Market, MD
    no idea, I seem to recall someone posting about that here on hearth.com but I don't believe they were talking about woodbrickfuel, possibly the older enviblocks? can't remember anyway. I might get a chance to fire some up this weekend if it drops down into the 30's overnight!
  12. hoof120 New Member
    Long Island
    haha I just called the guy to find out. He said it was heat smart. He is using the biger envi blocks this year.
  13. iceman Minister of Fire
    If you can get these types they are the real deal.... they burn forever and are the best substitutes to wood... now, I haven't seen the envi 8 but if its like these then they are good.... put 3 of these in a stove you are good for 8+ hrs with peak heat over 600...
    http://www.lignetics.com/fire-logs.html
    There are different brands but its the same idea
    These are the ones I have used and are great just to far to get
    http://www.hearthwise.com/page/page/506663.htm
  14. mmmmm New Member
    I cant seem to be able to find a price for these. Any one care to share a rough estimate on cost please?
  15. wood-fan-atic New Member
    Long Island, NY
    The envi-8 blocks are on L.I. CL for $285 a ton
  16. hoof120 New Member
    Long Island
  17. Flatbedford Minister of Fire
    I'll try 'em if I find them stacked on the side of the road or if somebody is giving them away.
  18. hoof120 New Member
    Long Island
    I thought the same thing when I heard the price. After trying them, I did the math and it was a better buy. $215 for a cord of wood in Yaphank. Most wood on LI is NOT seasoned and comes with a bunch on headaches. Bugs, mold, green, dirt, etc. I live in Nassau County. Firewood is over $200 for 2 face cords. NOT A CORD. 2 face cords. 2 face cords is not a cord. Oh did I mention it is semi seasoned, bugs, etc. etc. etc.
    Below is a posting for a cord of wood in Yapank LI. This was posted on CL
    FIRE WOOD FIRD WOOD!!! (Long Island yaphank we delivery free!)
    •1 CORD ………………………....$215.00
  19. wood-fan-atic New Member
    Long Island, NY
    I'm with flatbedford - I'll try 'em if someone is giving them away.......but other than that,I dont think I could spend cold ,hard, cash on any fuel that I could scrounge and burn for free. Also, although I am the first to agree that L.I. has MORE than its share of firewood scammers, wood CAN be found @ $150-$200 a cord. I'm now a self-supplied, L.I. wood scrounger, and proud of it. But itt's good to know that bricks are there if the need should arise.
  20. linuxat187 New Member
    North East
    Same deal in NJ, these blocks are being sold for $290.00 a ton.
    I too cut and split my own wood, but I'm thinking how much time and effort it takes to obtain 4cords for the season.
    I purchased a pack of 20block for $6.50, just a little taste and man i was surprised by the ammount of heat these blocks generated, and the over night burn was sweet, I added 6blocks at 11pm and it was able to produce heat until 7am...can't beat that...
    But I'm still too cheap to pay $290.00, maybe for xmas...
  21. wood-fan-atic New Member
    Long Island, NY
    ME TOO!!!!! Oh,well. hi-ho.hi-ho.off to split I go.
  22. Briggsy New Member
    Southern NJ
    Firestarter,
    Where in NJ did you find enviblocks?
    Thanks!
    New to the site (and wood burning), learning a ton!
  23. doglady New Member
    Central MA
    I am using Hearthwise logs. They say Hearthwise brand firelogs have a heating value of 8,730 BTU/lb and a .6% ash content @ 600 degrees Celsius. All I know is that I put about 3 in my woodstove at 10 PM and they are still bright red at 8 AM. They are expensive ($475 for 380 logs + delivery charge) but they are clean, easy to use, and give lots of heat. I've been burning wood for 36 years but am getting too old to stack, unstack and clean uo after it. I know Biobricks and Envi are cheaper but I do not know if they are better. I guess I'll try the Biobricks when I use up the Hearthwise and then I can compare. Has anyone used Hearthwise and compared them to others?
    Hearthwise are sold in Leominster, MA and Berwick, ME. The website is:
    http://www.hearthwise.com/page/page/506662.htm
  24. weatherguy Minister of Fire
    Central Mass
    doglady, the hearthwise are very good, I put three in my stove before bed and in the morning there were three red glowing sticks, about 8 inches and and inch round still burning, and they throw some good heat.
  25. Cape45 New Member
    Cape of Cod
    After reading the posts about Envi Blocks and others like them, I was wondering if it would be more efficient to burn them in a small fire box. I am thinking about trying them in a small Coal/Wood stove, something like an old potbelly stove. Has anyone tried something like that?
