Hearth classics question
rwhite
1,985
North Central Idaho
I will using a hearth classics corner hearth for my install of a BK princess. The website stated that if the stove is under 450 lbs the hearth can be installed over carpet. The princess comes in at 430 lbs. Do you think they consider the weight of a full load of wood? I have access under the floor that I could run some screws around the outer edge to prevent any bowing. Trying to avoid having to cut the carpet but will if needed.
That would be a question for the manufacturer of the pad. Seems that the thickness of carpet would be just as important as the stove weight.
