Yes, I do have a damper. I also had some super dry wood.... didn't seem to make any difference in how it runs.
Super airtight but lots of glass
Do you know what your house heat load is?I don't have nearly as much glass as what you have. I tried to take some pictures but having trouble uploading them.
x2Not being able to turn air down points to wet wood in my opinion.
I would leave the damper out for the moment. With dry wood, after a reload you should be cutting back the air after about 5-10 min. and the air control should be fully closed after 15-20 minutes. Then, close the pipe damper if the temperature rise is too intense or fast.Yes, I do have a damper. I also had some super dry wood.... didn't seem to make any difference in how it runs.
Actually my stack is 23'. Eight inside with 30 degree elbow and 15' outside. That's on a 12/12 pitch roof.My chimney is right at 30 feet of pipe length. There are two 30 degree bends.
Yes, the wood is dry. I got a meter for Christmas have been poking each piece of wood with it! The highest one so far was 16.7%. Most are around 12-14%. Also the damper is all the way closed right now and the primary air is about 1/4 open. Secondary burn has not been stable today and usually isn't immediately after cleaning out the ash.
Any suggestions on how to reduce the draft even further? Another damper??
