Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I would assume an old stone house with no insolation is the same as an unfinished basement for heating with stove ie sucks up heat?. if so I am very impressed with my stove heats 2000sqft all on it's own
Good to hear that the stove is able to keep up with it. Is it stone on the interior as well or are there studded walls hiding the stone? How much wood has it taken to heat so far?
I feel like having a stone house could be an advantage because of better sealing If it is constructed properly. All the weep holes in my aluminum siding make my house miserable in the wind.
just stone no studded walls.the walls read from 2 on bottom of wall to about 8about 4 ft and upi'm going to have to watch who i recommend this stove to it might push you out of regular house
Wow, that's cold. That's why medieval castles had tapestries hanging on their walls. For sure a good third of the fuel that has been burned this winter has gone to heating outdoors.
My neighbor has the same situation with his place , the bottom is stone the 2nd floor is stick built . His is 1800sqft. And heats with a small hutch rebel and his house is 75-80* all winter . I think IMO that the stone helps spread the heat in his house
Interior stone, yes. The interior walls on either side of my fireplace hold 85F to 100F, all day, every day. The exterior stone wall 8 feet away is still 52F.
Stone has an R-value of less than 0.1 per inch. Fiberglass insulation = 3.5 - 4 per inch.
insulation does make a huge difference my other house built in 91 has my dovre reachs 28 with out even trying brought it over to the cave had to basically hug it to keep warm needless to say it's back at the other house.was ready to sell before i bought the ultimate thank goodness it does the job
well bg from middle oct till end of dec 5 face cords from jan to end of feb 2000 lbs eco logs then ran out of money.buying 15 cords in spring and 15 in fall trying to get ahead a bit
A face cord = 1/3d of a full cord. Sounds like 2 2/3ds cords. Sorry you ran out of fuel. What is heating the interior now? In spring try to buy at least 4 cords of ash if possible. Oak and hickory are going to take a couple years to season.
I will add to velvetfoot's comments. I have been in a stone cabin in 80+ degree weather and found no need for an air conditioner. The rock may feel cold but that feeling does not go away in summer.
