Home design for wood heat.
Whatever your design for the shell, build a large hearth with a double flue to accommodate two fireboxes. One perhaps a high mass masonry heater for sustained temps and to keep the heat downstairs longer (radiant heat is omni-directional), and a smaller stove (cookstove?) for topping off and quick heat when needed. The best advice I've had is to design the main heating source for 2/3 to 3/4 of the maximum expected need and then top off with supplemental sources. That way the main heater will run efficiently most of the time and will not bake you out.
Ehouse
