So I decided with this nice weather that I should do a little cleaning. I swept out my liner, cleaned up my stove, and removed both blowers for cleaning and oiling. When I removed the combustion blower I must have knocked into the hose barb that is for the pressure switch and it broke off of the casing. Its an aluminum hose barb fitting with threads on the outside so that a nut holds it to the blower casing. After so many years of use it appears to have corroded badly which is why it only took a little bump to break it. Does anyone out there know of a replacement part number for this part? Is this part even a replaceable part or is it one of those things where they make you buy a new blower even though the one you have works fine its just missing a stupid $0.02 part. I found a part made by Enviro called and aluminum hose barb PN EF-019 but it doesn't appear to have any threads...maybe I can thread it? Any suggestions are appreciated.
PS I have a Whitfield Advantage II WP2
Thanks Everyone
Thanks Everyone
