Hey everybody,
Just thought I would share my plans for installing my add on wood furnace. It's a us stove hotblast 1500 I got from Northern tool back in september. After numerous calls and no show contractors I've had enough so I'm doing it myself (the stove has been sitting in my basement since the first of october).
I'd like to see what you guys think since most of you have been using these things for a while. Is it gonna work, am i doin the right thing or not. Brutal honesty please, I'm a big boy I can take it.
So heres my plan
I'm having a local sheet metal shop build me a piece to mount to the top of my stove instead of running two 8 inch pipes. Its gonna be 30 inch by 8 inch at the bottom and kinda triangle up to an 8 inch by 10 inch probably be 12 inches tall or so. From there I am installing a backdraft damper then a short way 90 over to a long way 90 then into my 8x10 duct. The first few branches coming off the trunk line i'm going to put metal to the registers and get rid of my flex ( just the three closest to the stove). I plan on installing a backdraft damper above the air handler for the electric heat pump. The wood furnace sets about 12 feet away from the air handler I have about 15 feet or so of ductwork to go through before it gets there. On the other side I have fiber duct board which I plan on leavin alone for now and flex duct coming off it to the other registers which i figure by then the air from the wood furnace should be cooled down enough not to have any worries. I am tapping into my existing cold air return with a 10 inch round pipe over to the cold air return box on my stove in which i will install a filter before the air gets to my fans. Im not to concerned of a power outage I have a 10,000 watt generator I can run a cord to to power the blowers and I dont plan on burning unless im home. I work shift work and the wife is kinda scared to use the stove. I plan on starting on this install in the next week or two if I can find my dampers I'm waiting on a couple quotes now. So tell me what you think good or bad lay it on me.
Thanks
So heres my plan
Thanks
