How I spent my weekend (the un-fireplace)
begreen
Mooderator
Staff member
104,744
South Puget Sound, WA
This was a sort of an anti-hearth weekend. We're getting ready to have the house lifted at the end of the month for a foundation replacement. Two weekends ago I took out the old oil furnace chimney from the 1960's. It was a real bear, tile-lined and built to the hilt. Every brick fought removal. I needed to rest a week to get up the energy for the next phase.
One of the decisions we had to make was whether to keep the fireplace or not. It is original, 82 yrs old, with decaying mortar and unlined, though I added a stainess liner when we moved in and later ran the pellet stove pipe up the liner. We finally decided that the old chimney wasn't in good enough shape to pay the extra 4 grand to save it. Removing it also will allow us to reconfigure the living room space. We'll move the Jotul into the living room with a corner hearth later this summer. Stay tuned for further progress reports on that.
But this weekend was demolition time. Pellet stove is now out and in the garage until I can clean it up for sale. Things went pretty quickly down to the first floor. The mortar was pretty crumbly and many bricks just took a tap to loosen. Elk, you would have loved (not) to see this. There were 4 separate takeoffs on this chimney (2 per floor) and the pipe with just a cap was still in place for each one! In some cases it was pressed right against wood from newer remodels. Oy! Good thing I only ran it with a liner! First floor teardown was a bear. Tons of debris and some bricks in the back were glued to a beautiful plaster? job. This stuff is like porcelain and is still standing. It forms the staircase wall which was the backside of the chimney. I've never seen plaster like this. Anyone have any ideas about what this stuff is?
For today, it appears that this old fireplace has a full masonry hearth. I'm getting ready to do some serious sledge hammering to as soon as I convince my already rubbery muscles that they can do this. I'm getting too old for this kind of work. Now what to do with a big pile-o-bricks?
Man that looks like major work. Demolition is supposed to be the fun part. You can reclaim all your old bricks and make a outdoor fireplace, other then that hopefully you got one of those roll off dumpsters you can chuck it in. Look forward to seeing the finished project.
Hmm. An outside fireplace would be nice. We were also thinking of creating a new gravel entry path with brick edging. And we are adding a greenhouse this summer that may get a brick floor. I've got to get them out of the way of the house-lifters soon, but will probably just move them into the adjacent field where the greenhouse is going for now.
Man, do not chuck that old brick! I tore out an old chimney on a 1869 farmhouse and used them for a walkway up to the front door... and it looked great!
If anything, give them away; brick is expensive and the old ones are usually worth more than the new ones.
In the Pac NW, brick will soak up moisture and then grow moss and algae. We currently have a brick walkway up to the house, but it's made with brick pavers the size and shape of a brick, but only about 1" thick. There is an incline coming to the house and in wet weather this path gets as slick as ice. I have to sand it regularly just for safety, so I'm a little shy at replacing the pavers with the old brick. But don't worry, they won't be seeing the dump. I'll give them away if we have extra.
what do i know about bricks, NOTHING. i would love to have some old ones. very few homes here uses brick, not shure why.
Thanks George. Beating on the mortar joints is only half the fun. Moving it out of the house to the truck was also great. There was a total of 2300 pounds of debris removed. And yes, by the end of the day cold beers were very welcome.
