How many of you pellet burners use a Humidifier?
Do you use a humidifier in your house during the pellet burning season?
  • I just want heat and I don't care about Humidification.
    Votes: 0 0.0%
  • Total voters
    122
LIpelletpig
279
Long Island, NY
This is a very interesting topic when it comes to health and the humidification of the air in the cold winter months. In any case with many heating sources available to us as all will add dryness to the air. I have found the pellet stove to dry out the air more rapidly and to lower levels of humidity in the home. Just thought it would be interesting to see how many others are interested in humidification.
Use a large console model and keep humidity above 40% as the house feels warmer. Can feel the difference in temp when i forget to fill it.
100% necessary IMO. I went out and bought one the 3rd day I had the stove running.
Wi Thundercat said:
Use a large console model.....
Me too, like this:
I have a humidifier and a tea kettle on the stove...but the damn water won't get hot enough to make good tea!
I have been thinking about picking one up. How do you know what size you need or what size to get?
Most humidifier in the mid and large range have automatic setting that you set and forget, so the size of the humidifier is determined by how many trips you want to make filling the darn thing. I find that I need about 2 gallons of water each day to keep the humidity between 45-55%. The smaller ones need more fillings, you might find yourself filling them twice a day. I actually think that the small ones are more mess because you have to turn them over the filled tanks and there is always a lot of dripping. The really large console madels are costly, but easily meet the needs of a moderate size home. The only problem I had with one was the cleaning. It is large and awkward. The console model usually has wheels so you can push them to a sink and not have to do any lifting. The gallon size ones won't take care of any more than one med to small room. In any event, be mindful that these units need to be kept clean. All wet things are areas where mold and mildew can grow. You will be surprised how dirty the filters can become. But with humidity, you will feel warmer, your sinuses will not hurt from the dry air, and the wood in your funiture won't develope huge cracks.
X2 ! Couldn't have said better myself. Remember to use a bacteria treatment every fill. ;-)
I don't know how anyone can run a pellet stove at full bore and not use a large humidifier. It is an absolute necessity for me.
I live in a pretty tight house, and as with most newer houses here in Canada it has an air exchanger to moderate humidity levels. Mine was undersized and we always had higher humidity levels than I wanted. Now with the pellet stove running, the air exchanger cycles on and off to maintain 45 - 50% humidity in the house without the need of a spearate humidifier.
To bring back an old post. I recently started running a console humidifier. Before I had it at 76 in the house it felt drafty and cool. After running the humidifier it is quite comfortable at 71 in the house. It's crazy how a little bit of water vapor can make you so much more comfortable
If your going to install a humidifier on your furance & run the fan while firing the pellet stove. I would suggest a
Herrmifier Model 50. It is about 6" square & uses a spray nozzle to inject moisture into the home. I installed one for my nieghbor & it works great. They cost about $100.
Here in NW Oregon we rarely see any time that the humidity gets low enough to worry much.
Now if your house is tight and you are using an appliance that can dry the iar out, the tea kettle or other means of adding little moisture can help.
A few years ago I spent a week in Las Vegas doing a trade show and the cold dry air of winter was horrible.
My nose felt like it was going to fall off and break it was so dry. After a day on the show floor I woukld go stand in the shower and just soak up the moisture.
I think it's pretty much a personal preference as to how much moisture to add.
Around here at our place the humidity will range about 40% to 60% without adding any more.
Where I live, when there is a weather event in the area, we are in the clouds 100% humidity so adding more is not needed.
During really cold dry times in the mid winter, if we notice high static conditions (the cat zaps itself when it noses something) we will sit a kettle on the Pellet stove.
Have fun
Snowy
Agreed.
Don't use a humidifier and we stay between 35-45% and have no problems.
Geez...this IS an old post! I just bought a humidifier the other day since the skin on my knuckles were beginning to crack. :bug:
Since reading this, I started looking online at humidifiers and am disappointed to say the least. Either they cost $350 bucks and have a 5 star rating or they cost less and have several negative comments about them. Can't I spend $100 or less and get a decent humidifier?
i spent $85 for my vornado evaporative.
it has a humidistat/adjustable humidity level setting, three fan settings and a 5 year warranty.
but it's rated for 1000 sq. feet. which is fine for my house.
i am thinking of bying one but not sure how big i need
how big is your house and how`s the humidity % with you vornado running?
my house is 2400 sq.feet basement and first level stove is in the basement.
I bought this one Bionaire BCM7309-CN off ebay for $26.99 shipped. It's on the FedEx truck for delivery today! 34% humidity this morning...feeling like a raisin.
Thats a little small for a whole house or even large room and your going to constantly be refilling it.
our house is 925 sq. ft. so for us this is fine.
i have the level set to 45% humidity.
it reaches that pretty easily. but when the stove is on, the hot air blows directly on the unit and it will run pretty much continuous.
ok so ill will need something around 200$ for my house
does your says for how many sq feet it will run for cause i was looking at some on line but did not say anything regarding how many sq feet
thanx for the info
Specs say between 900-1800 sq ft BIONAIRE BCM7309 depending on construction and my house is fairly tight. I don't mind refilling, and would rather keep refilling the tank with fresh water than have several gallons sitting stagnant for days at a time.
