How much of a difference is there between the pre and post LE versions?
ShaneMac
134
Ontario
Looking to replace my Regency F3500 due to missing the the pretty fire and no longer being primary heat after installing new heat pump.
I like to keep things simple and the PE's look to be best for simplicity and maintenance. No bolts etc to seize or break. Just remove the pin and good to go.
That depends on the model and year. For the Summit, not a huge change unless you go back a decade.
2008 but its 2 hours a way and not sure if I want to deal with drive lol. Honestly the baffle looks pretty good. 900 usd. Local store has a floor model LE for 2200 usd.
OK, that is not the Summit. It looks like a Super 27 or a Spectrum. It's a third smaller than the Regency 3500.
The 2008 model was great stove and this one looks barely used. $900 is a fair price if the rest of the stove is in this condition. Parts are still easy to get, but this may not need any. The difference between this year and the LE is that the 2008 had a linked secondary air control and the LE now uses the EBT2 to regulate the secondary air.
