    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Justaddwater New Member
    central Ohio
    It is warm here in central Ohio so I shut the stove down to give it a good cleaning. I have yet to clean the combustion fan this season (first season with stove). I tried to remove it after loosening the wing nuts (per owners manual) and it was not moving, almost like it was "welded" in place. I did not want to twist or pull to hard in fear of damaging "something"
    Is there a seal or gasket that can tear or break when removing the fan/motor? Nothing in owners manual about such.
    Any xxv owners with experience removing this fan for cleaning? How /what did you have to do to sperate the motor from the stove so it can be cleaned?
    Thanks
    #1
    Helpful Sponsor Ads!
  2. MSmith66 Feeling the Heat
    Central NY
    Once you have remove the wing nuts , you will have to twist the combustion blower mount counter clockwise to UNLOCK and pull the blower motor out.
  3. cantman New Member
    Pennsylvania
    This fan uses a steel lip which acts as a sealing flange and in turn is a tight fit. It will come out.
    You may have to rock it slightly back and forth to remove while turning it CCW. Additionally, have
    you also loosened the third bolt @ the bottom right of the fan? Mine is connected to a long shaft
    for easier access.
  4. Justaddwater New Member
    central Ohio
    Thanks!
    I worked on it tonight. Took some prying to break the seal but it broke loose.
    I was surprised how clean it was after 3/4 of a ton of pellets.
    Next time I know to wait longer.
    Thanks again!
Thread Status:
