Hi guys, I came across a smoking deal on a buck 91 insert. I am trying to help heat a 3300 sq ft home, so the bigger the better.
Well this takes an 8" liner..but how do I know if this will fit in my chimney. The house was built in 1995. I assume the damper and the metal that holds it all in needs to come out..but what about the rest of the way?
Also how much room does one need to have to be able to install the liner onto the stove. Looking at the min required opening specs of the insert..I have like a inch and half room on the height over the recommend min dimensions. I have no idea if its even possible with only 1 1/2 inchs to hook up the liner to the insert. unless it can be somehow hooked up first, then slide back into the fireplace?
Any help would be greatly appreciated. I want to jump on the insert deal, but just want to make darn sure it will fit in my opening.
I got a member from this site who hopefully will be installing the liner and the insert for me (thanks Matt!) , but like I said I want to make sure it will fit before ordering.
Thanks
Jay
Thanks
Jay
