WOODBUTCHER said:Sugar Maple is Hard Maple, Swamp Maple is "Red Maple" because of its pretty red leaves in the Fall....but is on the softer side like Silver Maple and punks out pretty fast.
WoodButcher
johnnywarm said:WOODBUTCHER said:Sugar Maple is Hard Maple, Swamp Maple is "Red Maple" because of its pretty red leaves in the Fall....but is on the softer side like Silver Maple and punks out pretty fast.
WoodButcher
Thank you woodbutcher.how can you tell the difference between sugar & swamp.
WOODBUTCHER said:johnnywarm said:WOODBUTCHER said:Sugar Maple is Hard Maple, Swamp Maple is "Red Maple" because of its pretty red leaves in the Fall....but is on the softer side like Silver Maple and punks out pretty fast.
WoodButcher
Just about every Swamp Maple I've cut into (except really young trees) has a red star pattern stained on the heartwood.
WoodButcher
Adios Pantalones said:The leaves are very different. The sinuses between the points on the leaves are rounded with sugar maple and they are sharp with red maple as well as silver.
WoodButcher
billb3 said:johnnywarm said:WOODBUTCHER said:Sugar Maple is Hard Maple, Swamp Maple is "Red Maple" because of its pretty red leaves in the Fall....but is on the softer side like Silver Maple and punks out pretty fast.
WoodButcher
If you put a tap in a sugar maple at the end of Winter, you'll get something that tastes OK.
If you put a tap in a swamp maple you get swamp water that tastes a bit like last year's leaves.
cmonSTART said:You know what last year's leaves taste like??
billb3 said:cmonSTART said:You know what last year's leaves taste like??
Yes.
Accidently.
I can send you some if you feel left out.
I have about half of last years 5 acres of oak leaf clean up. I use them for mulch as they don't compost terribly readily, especially if kept dry.
I use a high powered vacumn system.
There are doors one should not open while the system is running or you get a facefull.
I also own a couple acres of swamp.
I have cut cedar for fence in the past.
I have fallen in.
Know how that tastes, too.
I can send you some nice tannin laden swamp water to try, too.
crazy_dan said:do some of you guys work for the government?
because getting all worked up over what kind is it is kinda over complicating things.
