I hope it's okay~!
usefulidi0t
76
Kansas
PP130 - someway, somehow the dial got cranked to hi. No pellets in it... "summerized" (venting capped off, damp rid installed, etc.) and I just caught it after quite some time. What could of possibly of been damaged? vacuum switch? just thinking the venting being capped up could of been problematic. if so, how to do test? yes, i've learned best to just unplug it.
thanks,
mark
I don't think you will have a problem
The stove would have shut down
1= no fire = no heat
2= with vent capped no vacuum = no auger turning
even if the igniter came on it would have turned off in its normal run time
Reactions: usefulidi0t and ARC
Nothing to worry about as @johneh said.
yep, replaced control knob (unrelated incident), and test fired to check repair with some pellets.. runs just fine! thanks all
