I want to be able to load the stove and go to work. I'm having problems figuring out how that will be possible.
Past method was to prep coals, load er up and then wait until things looked to be fully engulfed and then close it down and leave. Total time generally 15 to 30 minutes to get that done.
New attempts aren't working for me. Tonight's latest attemp was loading it up on a hot bed of coals, shutting the door ASAP and then running for about 10 minutes with primary wide open, then closed it fully. That was about 2 hours ago and my temps have slowly climbed and now are around 675-700. I can open it up and cool it down, but this seems to be the standard procedure for me. Opening the door to cool it down is getting old. I won't be able to do this while I'm at work, and to only that, but the room is just too dang hot with this beast running at those temps.
Absolutely solid new stove, no air leaks, and my chimney isn't obscene to get some crazy superdraft.
I've tried leaving primary open, I've tried letting it smolder on coals closed primary from the start, but it still gets to going, eventually. Right now I'm burning two year old oak, a couple of pieces of pine earlier burned ok, but it was like a 3hr burn time and still hit 600 with those two splits on coals.
What am I doing wrong?
