'Accurate' doesn't really matter, unless you have specific wording in your owner's manual that tells you where to measure and tells you what temperatures to look for. Someday I hope all stove manuals come with that info; right now I understand they are few and far between.
What you want is a repeatable thermometer. After a few weeks of burning and watching the dial, you'll have a pretty good feel for what constitutes normal behavior for your stove... and also for what stove temperature corresponds to what room temperature for varying outside weather conditions. Knowing your stove's normal behavior, you'll be able to use the thermometer to keep an eye out for unusual behavior -- not getting hot due to wet wood, obstructed flue, etc, or getting too hot due to leaky gasket, unusual draft conditions, etc. You'll also be able to sync the thermometer to actions you take running the stove. "Hmmm, it's 25 degrees out. That means I want to cut the air back when the stove heats up to about XXX degrees on the dial." "Hmmm, that load looks just about burned out. I know I can get a good clean re-light if I reload before the dial gets down to YYY degrees". Stuff like that.
People mention actual temperature readings on here all the time ("let her cruise at 550 degrees"), but comparing readings like that between stoves, and between different thermometer placements, is an apples-to-oranges proposition. After a few weeks, you'll know what cruising temperature is for YOUR stove, and you'll know where to aim to get a comfortable room based on the weather outside.
Eddy
