We have a pioneer bay insert - it keeps shutting down & showing a fault, but we're never there to see what happens. Usually resets & starts ok. Stove store tech said change the board - I did but problem still there..... Help
Stove is a Pioneer Bay insert - bought in 2004(???) - came with house - used Dry Creek & another - tech from store just serviced it & reccomended board replacment - all lights flash
Doesn't seem to have a "code" - just flashing - is that the damper on the air intake?? - might be an issue since it also soots the glass a lot??? I'm at wits end & don't want to just start replacing parts.
I'm not farmiliar with that insert. But if it has a damper on the left side, I would pull it out some for greater combustion air flow. See if that helps with the problem.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
