Insulating Blanket
chopper698
29
On the older Jotul 602, is there supposed to be an insulating blanket on top of the burn plate? Also what is the
purpose of the blanket if there is?
There were no blankets in the old 602. Probably wouldn't hurt to have one on top of the baffle plate, though.
In my Morso 3610 it helps keep the heat inside the firebox so you cna get a good secondary burn going. Mine was packed solid with ash by the end of the year and was choking my exhaust so I removed it and couldn't evne get the stove body up to a couple hundred degrees.
Check online for an exploded parts diagram for your stove and if you see a blanket there you probably need one.
mayhem, the old 602 is pre-EPA, noone was putting ceramic blankets in their stoves back then...
Then you can safely disregard my suggestion.
