Is this crazy???
Binny Posted By Binny, Nov 16, 2012 at 6:54 PM
  1. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    Binny, it is never wrong to experiment so go ahead and give it a try. But my feelings is that you are assuming that heat is what dries the wood. Stick around and experiment and you will find that the wind will dry your wood faster than heat. I am certainly not saying that heat does not dry the wood because it will. But more importantly, it will allow for better evaporation of the moisture. So, if it allows for better evaporation of the moisture it would seem that leaving it uncovered would produce greater benefits. Put sun and wind together and it is difficult to beat.
    So I am wondering why anyone would want to cover the whole stack at all? Better uncovered to let Mother Nature do the drying for you and that is best done with wind. I think back to my farming days and one thing always come to mind and that is putting up hay for the winter. The hay has to be cut and then it has to dry before baling. Just think what happens if you mow your grass and bag it. That green grass has lots of moisture in it. Spread it out and it dries relatively fast. Would it dry faster if you put it into a bag and then put a vent at the top of the bag? I always noticed when drying hay in the field that if we had windless days, it took a long time to dry that hay. However, if we had windy days the hay dried much faster. Of course keeping the windrows straight those times could be a problem but that is something else.
    Our theory on drying wood is like this. We cut the wood in the winter months. No leaf on the trees and no insects to bother us. Sap is not so much of a problem. Following snow melt we then do all our splitting. As soon as the splitting is done, we stack the wood. Because we have time and space in our favor we don't have to stack in single rows. But the stacking is usually done by mid April and then we just forget all about the wood until the following December. Before snow piles up we then top cover the wood. This means that through most of the spring, all of the summer and most of the fall, that wood has been open to Nature. We think this allows for better evaporation of the moisture. By fall a lot of moisture has been removed. As proof of this, we stack our wood 4.5' high and by the time we cover the wood it is usually down to 4' and sometimes lower. This shows the shrinkage that is from the evaporation of the moisture.
    As stated, experiment! That is something that sometimes is not done enough. Also many times people experiment thinking about one thing they find benefits where they did not expect. But as for me and my house, we will continue to let Mother Nature be our friend. It has worked quite well for us for a few years now and we have not found anything better. Good luck.
  2. firefighterjake
    firefighterjake
    Minister of Fire 2.
    NULL
    Jul 22, 2008
    17,635
    3,899
    Loc:
    Unity/Bangor, Maine
    Another vote for spending more time and money on the "easy" way . . . giving the wood time and spending more time getting more wood to get further ahead.
  3. Tramontana
    Tramontana
    Burning Hunk 2.
    NULL
    Oct 23, 2012
    198
    117
    Loc:
    Wheat Ridge, Colorado
    I currently only have space for two cords and that is all allowable by zoning ordinance where I live.
    I cheaply sourced (ie scrounged) lumber wrap from a local lumber yard. These are woven tarps specifically designed for protecting Kiln dried lumber, so I figure they must be good enough for wood stacks. :)
    I know these are water proof to stop rain, and I think (always gets me in trouble) they might also be breathable to prevent excess humidity buildup in the lumber.
    Cheers!
  4. Isaac Carlson
    Isaac Carlson
    Feeling the Heat 2.
    NULL
    Nov 19, 2012
    250
    50
    It should be dry by then. I burn mine same year and it is plenty dry.
