Hello guys.
The door handle bolt (fastens handle to door) of my stove was loose allowing the door handle to spin too far up/down and get jammed if the door was swung open. I tightened the bolt (has a flat head screw driver head on the outside) just a bit which kept the handle from swinging past the guide grooves in the door. It worked well for awhile but now the bolt turns with the handle which tightens it when opening to the point where I cannot even open the handle enough to unhook it from the latch! I cant back the bolt out either for some reason now Did someone mess with the setup before I got it? It does not make sense to me that the bolt would be designed to turn with the handle which would tighten/loosen the bolt each time the handle was turned.
Thanks guys,
Nate
Thanks guys,
Nate
