Jotul 602
mass_burner Posted By mass_burner, Sep 25, 2013 at 11:49 AM
Thread Status:
  1. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    I'm about to install an unused, unpainted vintage 602 and have some questions:
    1. I have 3 baffle plates, is that all there are inside?
    2. Does anyone know how the baffle plates are arranged inside?
    3. Can I use unpainted? I do like its current cast iron look.
    4. Should I line the bottom with fire brick, sand, or something else?
    5. Does the round warming plate just sit on top? Does it need to be "cemented" in?
    Thanks.
  2. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,876
    8,625
    Loc:
    South Puget Sound, WA
  3. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    are you sure? i mean were they all painted at the factory in Norway? Mine look to be just cast iron, like a skillet.
  4. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,876
    8,625
    Loc:
    Yes I think so. If it was raw cast iron I would expect it to be very prone to rusting. At this point your paint is totally baked in.
  5. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    This stove has never been used. Not a trace of soot anywhere, gasket rope white and new. The seller said the original buyer bought it "in the 70's" and never installed it due to poor health.
  6. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,876
    8,625
    Loc:
    Wow, lucky you. That is a nice find. Be sure to do a few small break-in fires before getting the stove hot. Just use some kindling and let the fire die down. You want to gently drive any moisture out of the cast iron. Each fire can be a little larger, but not large. Shoot for about 250F max temp with the first fire, 300 the next and 400F for the third. Then you can fire it up. All three breakin fires can be done in the same day, just let the stove cool down in between.
    You'll find out if the stove is painted as soon as it gets up to 500F on the stove top. It will smoke for a bit as the paint bakes in, so plan to open some windows.
  7. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    after sitting for 40+ years, it does have some surface rust. so i'm going to wire wheel it in those spots. I may be able to tell for sure if it was ever painted from that process.
  8. peakbagger
    peakbagger
    Minister of Fire 2.
    NULL
    Jul 11, 2008
    2,812
    619
    Loc:
    Northern NH
    One thing with 602's is they dont like to jammed full of wood and the air choked off. They are very effective creosote producers when run that way. If you are trying to get an overnight burn, its the wrong stove. Just light it off and burn what you need and then let it go out adn restart in the AM if you need it. You will want to have plenty of kindling around but it doesnt take long to learn how to light them
  9. goofa
    goofa
    Burning Hunk 2.
    NULL
    Oct 7, 2012
    108
    39
    Loc:
    Central New York
    whats a good stove for over night burns or long daily burns... i know that is a foolish question but i have a crazy work schedule and am gone for long hours during the day and wood is my sole heat source.... i refuse to use my oil boiler
  10. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,876
    8,625
    Loc:
    Blaze King cat.
    Ashful likes this.
  11. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    Thanks for the advice, this stove is small, but the room it needs to heat is only 25 x 20.
    This stove is for our south facing patio with glass sliders all around and glass slider access into the house. We will only be using this stove while in the room, for winter "sunbathing" (roof also has 3 45" x 45" skylights), and relaxing on cold nights listening to music, etc.
  12. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,876
    8,625
    Loc:
    Perfect application. You will like this stove, it's a willing little heater. Just pay attention and don't get distracted when firing off a load. It can go from 200F to 800F very quickly if you forget to shut down the air. Add a flue pipe damper for better control and heat retention.
    RockyMtnHigh likes this.
  13. peakbagger
    peakbagger
    Minister of Fire 2.
    NULL
    Jul 11, 2008
    2,812
    619
    Loc:
    Northern NH
    I ditto the prior response, hard to meet a Jotul sized stove for that application. Just make sure you cut your wood to fit.
  14. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    Just out of curiosity, how much is a BK King Ultra non-cat?
  15. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,876
    8,625
    Loc:
    Not sure what Mass prices would be. I am taking a wild guess at near $3K?? Call a local dealer for the actual price.
  16. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    Got a chance to wire wheel the 602 before install this coming weekend. I can see that it had paint on it before, but most of it is gone now. I'm thinking, what's the worst that could happen if I run it this way? I did see somewhere they sold cast iron grey hi temp paint, like for exhaust manifilds etc.
    20130928_183011.jpg 20130928_183033.jpg 20130928_183051.jpg 20130928_183106.jpg 20130928_183124.jpg 20130928_183150.jpg 20130928_183203.jpg 20130928_183216.jpg
  17. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,876
    8,625
    Loc:
    Without paint the stove will instantly rust. Heat accelerates oxidation. Give it a good couple coats of Stove Brite paint in your choice of color and enjoy that beauty. Don't paint the hot plate though.
    You are one lucky fellow to have found an original factory condition 602. Treat it well. Get a stove top thermometer and install with a damper in the flue pipe.
  18. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    Is there any way to date this stove by the numbers inside?
  19. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,876
    8,625
    Loc:
    No idea, it could be quite old, they have been making that model since the 1940's I think. The newer ones had a UL plate on it so that might be a clue. Be sure to do some gentler break in fires with just kindling for the first couple fire. And put a 1/2" of sand evenly across the bottom of the firebox.
    PS: You do have the baffle and side burn plates for the stove, right?
  20. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    Yes, 2 side plates and 1 top baffle. Until I saw the diagram I had the side plates more toward the rear due to my limited experience with free standing stoves, the rear sides get the hotest, not the front sides. BTW, should I paint the inside pieces and the inside also?
  21. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,876
    8,625
    Loc:
    Great. There's no need to paint anything on the inside of the stove.
  22. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    double wall flu pipe damper is $63. with an older stove, I guess its a must.
  23. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,876
    8,625
    Loc:
    It will give you more control over the fire and less heat up the flue.
  24. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    I picked up some cast iron paint meant for engine blocks, 500 degree, will this work?
  25. 930dreamer
    930dreamer
    Burning Hunk 2.
    NULL
    Jun 3, 2013
    232
    32
    Loc:
    Amarillo, TX
    I'd look at the 1000 degree + range! 800 degree is probably a normal temperture range for a wood stove
Thread Status:
