I'm looking at picking up a Jotul F100 and am interested in venting it out the rear to be able to use the top to heat water and cook on. I've heard varying opinions on how much 'smokeback' one might expect with this setup and am wondering if anyone has this setup?
The overall chimney setup is looking like:
Elbow out the rear, 4 feet up to another elbow into a T and thimble. Should I go double wall or single wall black pipe inside? I assume double wall will help it draft and reduce smokeback, right? Seems quite a bit pricier though and I think I need an adapter to attach to the stove.
out the wall via the T and thimble (installer recommends black stovepip right into the T, is this correct?)
24 feet straight up.
Also wondering about the fresh air kit option. The stove will be installed in a well insulated 300 sq ft space. Should I go with the fresh air kit, and how will this effect the smokeback?
thanks!
thanks!
