Jotul Stove Temp versus Pipe Temp
BrotherBart Posted By BrotherBart, Oct 27, 2006 at 3:06 PM
Thread Status:
  1. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    I have been burning the new F3 CB in the office for a few days now. One thing I see is that started up and up to operating temp, around 550 - 600, the verticle pipe which is four feet into a 90 into the thimble is only around 250 degrees. It is great that the stove and the pipe are giving off most of the heat to the room but I am a little concerned that the stack isn't hot enough. The chimney is exhausting perfectly clear heat waves. Not a lick of smoke.
    Is this pretty much what the rest of the Jotul freestanding burners see or do your pipes run hotter?
  2. wahoowad
    wahoowad
    Minister of Fire 2.
    NULL
    Dec 19, 2005
    1,630
    132
    Loc:
    Virginia
    Outside of the pipe, or are you using a probe?
    I have a double-wall pipe coming out the back of mine so I haven't even bothered to check. I'm sure it is much cooler than single wall stovepipe. I am curious what the internal temp is though.
  3. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    Don't know on the internal temp. My measurements are on the surface of a single wall pipe.
  4. Corie
    Corie
    Minister of Fire 2.
    NULL
    Nov 18, 2005
    2,430
    1
    Loc:
    Halifax, VA
    The surface of the black pipe is not that far from the internal temperature of the gas.
    Although its a two dimensional heat transfer problem, one can approximate it as a plane wall, one dimensional problem and see that the surface temp of the steel, given a room temp of 70 deg F and flue gas temps of 300 deg F, there is about a 57 degree temperature difference between the flue gas in the pipe and the outer wall of the pipe, assuming neglible insulating effects from the creosote on the inside of the pipe.
    Maybe I'll throw together a rough chart of values for various outer flue temperatures that will tell you the actual temp inside the pipe, possible a helpful wiki item.
  5. mmichaud
    mmichaud
    Member 2.
    NULL
    Sep 6, 2006
    63
    0
    Loc:
    South Milwaukee, Wisconsin
    For what it is worth, I have a Jotul Castine and when my surface temperature is about 550 degrees my stack thermometer reads about 350-375 degrees. My thermometer is about 12 inches off the surface of the stove.
  6. MountainStoveGuy
    MountainStoveGuy
    Minister of Fire 2.
    NULL
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    Sounds like efficient burning BB :) Hot stove, low flue temp, no smoke! whoo hooo!
  7. Todd
    Todd
    Minister of Fire 2.
    NULL
    Nov 19, 2005
    9,229
    349
    Loc:
    Lake Wissota
    I don't have a Jotul, but my pipe temps taken 2' above the stove on single wall are usually somewhere between 275-350 when the stove top is around 450-600. I think as long as it is burning clean there should be very little creasote forming thingies, so newer stoves can get away with a lower stack temp than the old pre EPA stoves.
Thread Status:
