whatisup02 said:Its about 4 cords. Plus I have another 3/4 cord that's not in the pic. I can say that stacking it up and making it look good/not fall over is not as easy as I thought it would be.
stejus said:Nice pile of wood. Next time I suggest you leave space between each row, like at least 6" or so. This will allow the air to pass through to move the moisture away.
zapny said:whatisup02 said:Its about 4 cords. Plus I have another 3/4 cord that's not in the pic. I can say that stacking it up and making it look good/not fall over is not as easy as I thought it would be.
Nice start whatisup02. What type of wood takes up space in your stacks?
zap
You've got a nice, early start on drying that Ash. If it was me and I had time I would core out the two middle rows and stack them, with a space between the rows, on another set of pallets. Ash dries fairly fast, but you might be pushing it with that many rows stacked together and against the building. You're on the right track, though. Good luck! I don't know, maybe super-dry wood isn't as critical with a furnace...DexterDay said:stejus said:Nice pile of wood. Next time I suggest you leave space between each row, like at least 6" or so. This will allow the air to pass through to move the moisture away.
Nice Stacks.... X2 on the room for air. Will help to "Season" it better. Sun and Wind are your friends with wood....
Great start... You will not be disappointed next year. Very few start getting wood before they get the stove installed.
whatisup02 said:Its all ash.
zap
Trktrd said:I stack in a similar fashion but run a piece of fence wire across the top and tie to the T posts to keep them from spreading.
BillsWS said:whatisup02, after you drive your metal end stakes in, find some scrap cord or rope or even wire and tie them together at the top. As you pile between the poles, they won't lean out as the wire/rope/cord holds the tops of the poles in line.
ProjectX said:The more solid the the ends/cross stacked the stronger the whole stack. This is my first year stacking so take it with a grain of salt but seems to work for me.
Gl
X
Notice that we do not use anything at the end of our stacks. I kid zap because he uses t-posts but it is just in good fun. Learning to stack the ends comes just by doing it. At first it may seem simple then the danged thing falls over. Do not despair as it can be done and you will be amazed at how easy it can be. I've had one stack fall over in the last 50 years or so.
Good luck.
