Scrib said:Hello all. It's been a brutal winter here and the gas bills are just out of control. That and my wife and I decided not to put a fireplace in the hosue when we built as we couldn't make up our mind on how/what we wanted. My Dad introduced me to pellet stoves and I've done quite a bit of research.
Our home is 2500 sq ft. and has a very open concept. We were thinking of putting the stove in our great room, which has an 18 foot ceiling and that second floor has an overlook down. Even when the we're only heating the first floor (zoned heating installed in our home), the heat gets up to the second floor. So I'm quite confident that the stove placement would be ideal for getting heat to both floors. And the corner where the stove would sit is on an exterior wall, so venting would be cake.
The two local stove shops carry Harman and Avalon/Lopi and everything I've read seems to lead me to think Harman is a better choice. Right now, the XXV and P68 are the two in consideration. Any thoughts?
Only concerns are:
- Blower noise. The stove will sit in the room where we watch TV.
- Too much heat. Obviously the point is to create heat, but it could get quite hot since we spend a lot of time in the same room where the stove will be.
- My son. He's only two and obviously very inquisitive. I am thinking a good metal gate to corner the stove off will work.
Any thoughts on either Harman model? The goal is to reduce natural gas dependancy during the winter months. Budget --- There really isn't one. I want to make sure it's done right.
Thanks all.
Hi Scrib - you mentioned wanted to cut down on the cost of gas (I think you gave a figure of about 0.8814/therm). You may want to spend some time with the fuel calculator (https://www.hearth.com/econtent/index.php/articles/fuel_cost_comparison_calculator/). I make gas at $0.8814 (80% eff furnace) to be equal to pellets at about $125. Best bang for you buck may be to either improve insulation, or install a gas fireplace.
If you want the lowest cost per BTU, you should look at a wood stove. However, it will be more work.
If you are really concerned about your son, you may want ot do a search on Hearth Gate. See https://www.hearth.com/econtent/index.php/forums/viewthread/34575/.
Pellet stoves do make noise. Some don't mind it, others cannot stand it.
Having said all that, I do really enjoy my Harman. However, if you primary goal is to save money, I would suggest you crunch the numbers a bit more.
Cheers
Kenny
