VirginiaIron
Can any splitter run atf or the thin hydro oil? I am using TSC hydraulic fluid, ?40?. If I run atf will that speed things up?
Stopped in to TSC today and snapped a few photo of the "fast models", the 40 was not available at this location. One thing I noticed USA the 30 lifts the wheels off the ground when the beam is vertical. And, in the vertical position, both models kink the return hose, I'm not sure if it is design or the assembly.
These two units were displayed vertically. what is surprising is these hoses are a lower psi than the others- since there should be no significant restrictions through the filter. I wonder if this hose is a regular non-wire reinforced hose.I'm surprised nobody seemed to give a hoot that the display model had kinked hoses.
Or are you the one who switched the machine to vertical and discovered the kinked/tight hoses?
Probably, mine is just held on by hose clampThese two units were displayed vertically. what is surprising is these hoses are a lower psi than the others- since there should be no significant restrictions through the filter. I wonder if this hose is a regular non-wire reinforced hose.
I've seen worse. A few years ago, a local TSC hall all models displayed in the vertical position with kinked hoses. Every single one of them! I told them about it, and that all they had to do was loosen the swivel adapter and spin the hose until the kink is gone. It takes two open ended wrenches, and it's not a messy job at all.
same here but the only way to decrease return time is bigger ports and related circuit constrictions or a second splitter
I'll be honest with you, I've always been a big proponent of Honda and Subaru engines, myself. But then again, I also own Briggs, Tecumseh, Kohler, and Kawasaki powered outdoor equipment, and haven't found any of them to be less reliable. Well, one exception... the Kohler experienced three broken fuel tank fittings in three years, but I eventually found the reason for that, and that was a ca.1966 Kohler K301AS.I've had my Troybilt 27 ton with the Honda engine for a long time now, jeez it must be 10 years old I'd say. If it finally ever gives out I would replace it with one that had a faster cycle time, but I will say that I am amazed with the Honda engine. It can sit and not run all summer, I can then roll it out of the shed in September, put gas in it, pull the cord twice and it starts, every single time.
That machine has some pretty impressive spec’s. But for me, I’d really only consider a 37 ton machine if I had plans to “downgrade” the cylinder from 5” to 4”, for faster cycle times. Their 37 ton machines come with a 22 GPM pump, which is way better than many competitors that only give you 16 GPM, so their cycle times aren’t all that bad. But keep in mind that this 22 GPM pump would give 6 second cycle times on a 4” x 24” cylinder, if you had such a cylinder made with 5/8” ports.I do prefer the 37 ton- full beam product and for the money I think this is a better choice than the $1k tsc unit.
https://www.ruggedmade.com/log-spli...-lift-48-563-322-rt06pc-13-225-150-ll-ct.html
Any thoughts?
I just bought a DHT 22 ton splitter on Ebay , $829 and free shipping.
I've had the predator 20 ton splitter for three years and it plows through anything I've thrown at it, but I scrounge way too many monster trees and I really want the ability to split vertically, instead of using a ramp to get them up on the beam
Who has the 37 ton machine with a 22gpm pump? I know someone here had the same 37 ton Menards splitter I bought last Black Friday, maybe it was VirginiaIron? Anyways those splitters have a 17gpm pump and the relief is set at 3800psi... And I might get a 4" cylinder for it in the next year or so. I don’t know yet... I haven’t even put a hour on the splitter yet as all of my splitting it in the spring or early summer.That machine has some pretty impressive spec’s. But for me, I’d really only consider a 37 ton machine if I had plans to “downgrade” the cylinder from 5” to 4”, for faster cycle times. Their 37 ton machines come with a 22 GPM pump, which is way better than many competitors that only give you 16 GPM, so their cycle times aren’t all that bad. But keep in mind that this 22 GPM pump would give 6 second cycle times on a 4” x 24” cylinder, if you had such a cylinder made with 5/8” ports.
22-ton pro’s:
- typically faster cycle times
- plenty strong enough for 99.99% of everything I’ve ever tried to split
- easier to move around by hand
- typically less expensive
37-ton pro’s:
- splitting the few rounds per decade that my 22 ton balked at
- bragging rights (“mine is bigger than yours” BS)
I don’t mind noodling the one round (if that) per year, that my 22-ton machine can’t split. Or put otherwise, if you run into much stuff you can’t split with 22 tons of force, you need to find a better wood supply.
I won’t deny the “fun factor” of running bigger machines, but both of these are so small that they don’t really register, there. These ain’t 100 HP wood processors.
