Looking for ideas to build my own insert
K2Orion
71
St. Louis Mo
Anybody build their own insert?
I have a small firebox in my masonry fireplace and am using a smokedragon insert now. I would like a more efficient insert but my choices seem to limited by the small size of the firebox. It has a 23.5" x 23.5" opening and the back is closer to 18" wide. I have looked at the Lopi Answer and similiar inserts but think a "custom" homebuilt might better suit my needs.
I'm thinking I would try to find a used door with glass as a start. I have (6) 30"x 60" sheets of 3/16" steel plate that I rescued from a dumpster at work. I also have a 30"x 30" square of 1/2" plate. These should provide the bulk of the raw materials. I am confident in my welding abilities and have all the tools and space needed to take on this project.
BUT, I do want to research this as much as I can and hopefully only build this once.
So, anybody build their own insert? Got any tips? Any web links or other reference material that would help?
I plan to draw up something in paint real quick and post it to give a base for people to tweak.
Only issue I could see would be your homeowner's insurance not writing a check if something went wrong. Even if it wasn't the fault of the stove, and you got an inspection this would be a get out of jail free card for an adjuster.
Hmmm. Never considered the insurance situation. But I wonder how this would be any different than a wood stove from yester-year thats still in service. I'm sure not every woodburner in use is UL listed.
But, I'd prefer this post to stay on the original topic, not dissappear into the insurance vortex.
Leave room for the fire brick and a baffle at the top to take advantage of higher box temps.
Make a second channel for air that opens and feeds tubes at the top of the fire box, as you close the primary air.
It's a great idea and not rocket science - please post pics as things happen.
Keep the lever(s) and mechanisms as simple as possible - Quad simply welds a flat piece of steel to a rod for their air control on the 4100i - the flat piece of steel rides in a channel and is the air "gate".
