Hi all, I am new to this forum and have very much enjoyed the great feedback within. I am not new to burning wood; as I have an active Maple business for many yrs and have had a Woodstock classic stove in the home for many yrs until it was replaced. My Garage is half finished in my long ranch house at the far gable end of the house. We have a Harmon pellet stove in there for over 10 yrs now. This room goes up 3 steps into the rest of my very 70s built house[not open plan] into my kitchen and then living romm/hall next, then the bedrooms at far gable end 78 feet later. We used to have the woodstock [early model-non epa] in the living room going out the masonary chimeny. This would drive us out with a lot of heat in the bedrooms, as we like them around 62 to 64 now-a-days.
My question is that I am thinking of running a new woodstock fireview where my pellet is now. A little info on this, I think Harmon is the best there is with pellet stoves. I simply want to go back to wood for many reasons. Loosing power for one, I have a lot of residual wood that I butt off from sugaring that will be a good lenghth for the house. Also albeit it is 75 in the finished garage by the time in goes into the large breezway next then the kitchen[all straight line] I start loosing the heat for the hallway next and the bedrooms to follow. In the fall and spring the pellet will heat the house pretty much. I feel that the Soapstone will be hot in the 12 foot wide by 24 long room it will be in, but will make those next couple rooms down a little warmer than my best now. This in turn could go farther towards doing more to heat my house than the pellet stove. I also miss that kind of heat as well. My relatives have the same one on a small ranch hs and it is 85 in the stove room and 75 in the far reaches of there house, even though it is smaller than mine.
I am hoping for 80 plus in stove room and 70 plus next room or so and mid 60s is fine for the rest. I should mention I have a vt casting propane stove in the living room where the old soapstone used to be. I also have a new buderous propane furnace in the basement which is mostly unfinished and stays at 55 even when it recently was 20 below here.
Sorry to be long as I needed to decribe layout. What do you think the New soapstone would do as I decribed here?
