I have an Endeavor right now that I burned the last two seasons. It's had about 10 full cords of wood put through it to this point. The bottom dollar on mine would be 1000 so I think the price is about right. It will be replaced by a Blaze King Princess for this upcoming season.
The stove is a great little heater and a blower is a must imo. I'm heating nearly 2K with at and it's done a good job. The overnight burn on the stove is a piece of cake, load it at 10 or 11 pm and restart in the morning about 7am with no issue, some mornings the blower will still be running. The daytime burn is a little tougher, I load the stove at 7am and get home from work between 6-7 pm, the stove still has plenty of coals for an easy relight with full size splits but the heat output isn't contributing to anything. I'd say you get about 6 hours of useful heat out of the stove before temps will start lowering in the house.(this is during the cold part of the winter) Obviously this will vary greatly by the house and how insulated/tight it is.
I've had two issues with the stove since I've owned it and one was my own fault. I screwed up the door gasket and it lost a roll pin out of one of the burn tube. The roll pin was obviously an easy fix and pretty common from what I gathered.
The stoves pros:
Great convection design, it moves the heat around my house very well.
Square fire box take a 18" split n/s or e/w, this is HUGE for me. I only burned it n/s though.
Bypass that eliminates smoke spillage during start up/reloads.
Brick baffle in the top of the stove so you don't have to worry about screwing up a board baffle with a poker or split.
Close clearance to combustibles, just over 4" on the rear!
Only a couple cons:
Ash lip needs to be lower below the door.
Depth of the firebox should be deeper, when opening the door ash would spill out frequently.
Here is a good review written on the Endeavor by Pagey.
https://www.hearth.com/econtent/index.php/forums/viewthread/37171/
If you have any specific questions let me know, I should be able to answer anything you need.
