    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. cyclone Member
    North East Pennsylvania
    I have been burning with the Endeavor for two years now. This will be my third. I do have some questions concerning temps, etc..
    I use two magnetic stove thermometers. One on the outside of the stove pipe about 18 inches above the stove and one on the stove top.
    Questions:
    Typically what temperature does your thermometers run when cruising?
    When starting a new fire with a bed of coal's what temps do you start to shut evrything down for a good burn?
    #1
    Helpful Sponsor Ads!
  2. eclecticcottage Minister of Fire
    WNY
    We don't have a thermo on the pipe, it's a double wall.
    This last season was our first year burning. We have a rutland thermo on the top of the stove.
    The Republic (sister stove to your Endeavor) typically cruised at 500-550 and I shut down at about 600.
  3. MarkinNC Feeling the Heat
    Leicester, NC
    I have a stove top and a magnetic thermometer 24" above the stove on double wall pipe. I shut the bypass when the stovepipe thermometer is about 150 (good draft). I start shutting down the primary air control in the low 500 range and try and keep it in the 500 range but often end up cruising at 600 and change. Some fires want to burn 700 or more, these stove like to run hot in my experience. My stovepipe thermometer runs about 200 to 250 as I recall when cruising.
  4. rdust Minister of Fire
    Michigan
    Mine ran hot...hot...hot, it would "cruise" in the 700+ range on a full load with a decent coal bed with the blowers running.
  5. Treacherous Minister of Fire
    WA state
    I try to cruise it in the 500-550 range. My flue temps usually run above my stove temps though.
  6. jensent Member
    central Ill
    Use telescoping dbl wall stove pipe. Thermometers are on the cook top (lower level). Have a Rutland and a Woodstock. Both read the same. Factory hi-temp chimney18ft, stove pipe 5.5ft. for a total of 23.5ft straight up. Can clean the chimney from the first floor by removing the dbl wall. Burn 24/7 during the heating season. Wood is seasoned c/s/s for three seasons. Clean chimney once every 3yr. and get about a cup of dry powder. Endeavor has heated our house for 9 seasons. We try to never let the temp above 500F. Run plenty of air(about half open or more). Usually keep it at 350F. Wood is what ever the tree service dumps in the side yard.
    Tom
  7. lopiliberty Minister of Fire
    Mineral County, WV
    I have the liberty which is the big brother to the endeavor, although there is times I wish I had the endeavor. With a full load of my seasoned oak, ash, and locust it is impossible to keep the cruising temps under 700 sometimes 750 keeping the house between a toasty 85 and 90 degrees and if i get carried away sometime well above 90. After last year i found the best way to keep the temps down was to put two spits of green wood in with the dry stuff but then that would only take the cruising temp down to about 650, but after the green would dried out and stopped hissing the temp would shot back up again. My flue temps usually run between 300 and 400, but have been as high as 500 on single wall pipe
  8. Pagey Minister of Fire
    Middle TN
    My experience is akin to rdust's. Ours likes to cruise around 700 to 750 for an hour or so on a full, fresh charge with an established coal bed. I've found that I can control this better with smaller loads and, with good, dry fuel, closing the primary air down sooner than I did when I first started operating the stove.
  9. jensent Member
    central Ill
    To keep the temp. down build a smaller fire. We always use dry wood. I think using green wood is a bad idea and will foul the chimney. Don't like the idea of a chimney fire. Just my opinion.
    Tom
