    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. mreortiz New Member
    Hello everyone,
    I purcahsed my Lopi Leyden Pellet Stove 4 years ago and I've been very pleased. However, this season I noticed the stove doing something it had never done before. The convection blower will stop blowing for about 5-8 minutes and the start back up. There doesn't seem to be a pattern as to when this happens.
    I called the store where I purchased the stove. They asked what my heat and fan settings were. I had the heat setting on level 1 and the fan on level 6. The owner suggested that the blower may have been cooling the flame to a point where it wasn't warm enough to keep the convection blower active. He suggested either lowering the fan level or raising the heat level. Well, I raised the heat level to level 3 while maintaining the fan level at 6 and I still have the same issue. The convection blower will randomly stop blowing while every other aspect of the stove functions properly. And I believe the stop to be plenty hot enough for the convection blower to remain on at all times.
    I have cleaned the convection blower recently. I vacuumed the dust bunnies and cleaned the impellers just this past week. Any suggestions as to why this could be happening. I truly don't recall this ever happening the first 3 seasons of having this pellet stove. Any help would be appreciated. Thank you.
    #1
    Helpful Sponsor Ads!
  2. SmokeyTheBear Minister of Fire
    Standish, ME
    If you haven't cleaned that convection blower and its motor and oiled its motor if oil able your blower could be overheating and shutting down as soon as the motor temperature drops far enough the blower restarts. There is thermal protection for the blower motors.
    If the blower motor is oil able they normally need 2 drops every six months and if this hasn't been done you may have to work some oil into the motor by spinning the motor by hand and applying more oil until it spins freely.
  3. mreortiz New Member
    How would I know if the motor is "oil able"? It never mentions that in the manual. And where would I apply the oil. Is there a place Specifically for the oil or do I simply squirt away at the blower where the impellers are? Thanks for the help, sounds like A possible solution!
  4. John C. New Member
    Wethersfield Ct.
    My Avalon has two yellow caps on the motor you pull off and add a couple drops of oil.
  5. SmokeyTheBear Minister of Fire
    Standish, ME
    Normally the motor makers plate will tell you what to use for oil if it is oil able, normally it is sae#20 wt NON DETERGENT oil, which is what is in the 3 in 1 blue and white can or bottle. Always check the makers plate on the motor. The oil ports may or may not have plugs in them there are two and they are in-line with each other along motors shaft one on one end and the other on the other end.
  6. richkorn Minister of Fire
    SE CT
  7. mreortiz New Member
    Thank you everyone for your postings. I have oiled the convection blower with the 3-in-1 blue can last week. For the first few days it was working no problem. However, the issue has returned and the blower is randomly shutting down again. I always have the fan on level 6 while having the heat between levels 1-3. The shutting off happens on all the levels we use. Could it be that the blower needs to be replaced after 4 years?
  8. nksdad2007 Member
    Central, Maine
    Have you tried turning the fan down to maybe 4 and see if that fixes the issue? maybe it is cooling the stove off too much?
  9. SmokeyTheBear Minister of Fire
    Standish, ME
    It is possible that you haven't got enough oil worked into things yet or that the blower is not recoverable.
    Could be, but is the convection fan controlled separately from the the POF sensor (I don't know and am too lazy to read another manual to find out)
  10. quickrch Member
    Northern, VA
    mreortiz My Avalon did this for the first time yesterday but it didn't turn on again. The stove got hot enough that the dog started barking and it had that chemical smell they do when they get too hot. I wasn't home so they just shut it off until I arrived.
    I am about 20 tons in running pretty much non stop for 3 years of winters and I didn't realize I had to oil it. I didn't see it in the manual though I had read about it here. Like you I did a cleaning today and will be putting oil in and starting it tonight again to see how it goes.
    Let me know if you find a cause. I'll do the same.
