Thank you in advance for your advice!
I have a 20 yo Dutchwest 2462(xl), catalytic, with an 8'clay-lined brick chimney. The chimney is 3 stories, cellar thru the 2nd floor and out. The stove is on the middle floor.
Since I bought this house, a problem has developed that is pretty unpleasant. Water runs down the chimney flues and flows out of the cleanouts, it is nasty stuff, and up to a couple gallons per day. I have ruled out a leak in the chimney and foundation, the water only comes when I am heating with the stove.
I'm coming to the conclusion that this water comes from condensation, which leads me to suspect that the stove is not functioning properly. This was not a pre-existing problem, but has been getting worse over 3 years.
I recently changed the catalytic converter and thermometer, the temps top out at 900 F, but commonly run at 500-600. The rest of the stove seems tight enough.
I'm burning 4-6 month old oak, which is probably pretty moist, but it burns very well, no problem getting it started.
Any ideas? Thank you very much
