    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Eatonpcat Minister of Fire
    Eaton Township, Ohio
    Could someone please post a picture of their gauge and splain to me how to use it?? I am looking to order one this evening or tomorrow. Any recommendations on which one to purchase??
    As always, thanks in advance!!:cool:
    #1
    Helpful Sponsor Ads!
  2. Aquion New Member
    Portland, CT
    Eatonpcat likes this.
  3. lbcynya Feeling the Heat
    W Michigan
    I just put one up for sale... Old school style (less $$$), works perfectly!
    http://www.hearth.com/talk/threads/...ideal-for-checking-pellet-stove-draft.105008/
    Easy as can be to use, just need a small tube and whatever method necessary to connect to your particular stove. Since I could take my pressure measurements while the stove was cold, I used modeling clay to form a seal around the tube/hole to prevent any air leaks around the measurement hole. Ideally, you'd want a small fitting that would screw in and attache to the hose, but it's not rocket science.
  4. Eatonpcat Minister of Fire
    Thanks guys...lbcynya,Why are you selling (dumb question, obviously you don't want it any more)?? Seems like a good price!
  5. Woody1911a1 Feeling the Heat
    Marblehead , Ma
    that's a really good price . same gauge as i have .
  6. lbcynya Feeling the Heat
    W Michigan
    Really can't adjust draft (to any real extent) on my stove, so I really only need it once to see what my baseline was. So, might as well make room in the closet and let someone else use it...
  7. Montnl New Member
    Northwestern, MA
    I have Dwyer MARK 22 that bought in a yard sale for almost nothing. Brand new are as high as Ibcynya's. I use a rubber stopper with 1/8" brass tubing bought in ACE hardware to connect in the stove. I have to plug one of the holes for the air wash inlet and connect the meter in the other hole to get better readings. When the 25-PI is cold readings go to 0.3" and hot go to 0.13 - 0.15", anything below 0.10" means the stove or burn pot needs cleaning even with the flame looking good.
  8. DAKSY Super Moderator
    Here's a magnehelic from the Harman Pellet Training Handbook & some basic instructions on its usage...
  9. Eatonpcat Minister of Fire
    Thanks...
    DAKSY likes this.
  10. Eatonpcat Minister of Fire
    Received yesterday as good or better than described!! Thanks 'lbcynya'. Now to figured out how to use it!!
  11. Joe and Kelly Tomeno Member
    NY
    I see them on ebay and it says measures water...are these the same?
  12. Woody1911a1 Feeling the Heat
    Marblehead , Ma
    yes vacuum in inches of water .
  13. Woody1911a1 Feeling the Heat
    Marblehead , Ma
    go to the enviro web site and download the service manual .
  14. Bioburner Minister of Fire
    West central Mn
    inches of water, alot less than psi. I have a liquid one on a radon mitigation system.
  15. ironpony Minister of Fire
    mid-ohio
    wish I would of seen this sooner I would of sent you one. I have quite a few around the shop doing nothing
  16. jtakeman Minister of Fire
    Northwestern CT.
    You prolly won't have many for long! ;)
  17. Eatonpcat Minister of Fire
    Thanks, I appreciate the thought...It was only $37, so it didn't hurt the pocket book!
  18. reg1952 New Member
    Guelph Ont.
    I mounted mine on the wall behind the stove and teed into the line going to the vacumm switch.I can see what its doing any time.
  19. Woody1911a1 Feeling the Heat
    Marblehead , Ma
    that will not give you the correct reading on on enviro stove !
  20. Woody1911a1 Feeling the Heat
    Marblehead , Ma
    there is a port(hole) you need to take the reading at . download the service manual .
  21. smalltown Feeling the Heat
    Western Maine
    Can a magnehelic be used on Quadrafire Castile stoves? I am not aware of a test port?
  22. reg1952 New Member
    Guelph Ont.
    Yes you are right.But what I did was take a reading from the test hole and set the damper.Then I teed into the line at the back.My reading is about .1 inch off the spec.. I just make sure it stays in that new range.
    jtakeman likes this.
  23. jtakeman Minister of Fire
    Northwestern CT.
    Sure you can tee it into the vacuum switch hose. But there is no damper adjustment on the quads. So it would be for giggles and maybe keeping tabs on your venting.
