I need to change my exhaust booster / blower motor. To remove it, it seems like I have to remove my manifold. Do I need to replace the rope gasket or can I use a high heat gasket in a tube like used on automotive engines?
rap69ri I'm assuming that you mean rope gasket and not just rope. I know that parts for this stove aren't easy to find. Can I just buy some bulk rope gasket, or does it have to be preformed and have you ever worked on these stoves?
When I replaced mine a couple of seasons ago I bought the gasket from Lowe's or HD and cut it to fit. I used the high temp silicone to keep it from moving while I put it in place.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
