Masonary Fireplace wood inset - HELP!!
Beamer
11
Toronto, On
I need a little help from all you pros... here it goes..
Interested in:
I am in the market for a wood fireplace insert. The 2 brands I am looking at are Regency and Napoleon (I was looking at Jotul, but they are quite a bit more pricey)
Regency i2400 and Napoleon 1403
About the house:
I currently live in a Bungalow with a footprint of about 1400sqft. It is an older house from the early 60's, so we might be a bit limited by a non-open floor plan. I would like to add the insert into the basement fireplace which is directly below the main floor foreplace in the living room/dinning room.
The basement room with the fireplace is about 25x13ft. The fire place is at the end of the room on an outside wall. Outside of this room is a large hallway area with doors that loead to another room larger than the last and a large laundry room.
The stairs to the mainfloor are also in this hallway.
The real question:
Now, with the floorplan being of a non-open concept nature, will the heat from either of these 2 inserts be able to heat the rest of the basement? Will it radiate to the main floor at all?
Shoulod I be looking into another sort of insert? Are any brands better than the rest?
Obviously I do not think that this will heat my entire home, but I'm hoping it will do about half and let the gas furnace do the rest.
I live in Toronto, Ontario, Canada.
Thanks in advance for any help you can give!
Thanks
Ryan
Hi Ryan, welcome to the forums :)
Get ready for many questions. I'll start ;-)
Why the basement? If you have a useable fireplace upstairs, and that is where you spend most of your time, I'd rethink that. You'll get more benefit from the insert being in your main living area.
2nd thought is a free standing wood stove upstairs. Again more heat benefit.
If the basement is the place you really must have this, is it insulated? If not, you have a problem losing heat through the walls.
A floor plan would help here.
Start typing/drawing, etc :)
Hi Eileen,
Well, we just had our basement renovated, so we were thinking it would be a nice addition. We do plan on spending a fair bit of time downstairs. We also just had a baby, and his playroom is down there to... it will give us a chance to get all the toys and stuff out of the main floor. :)
A freestanding stove would not really work as the fireplaces are already in place.. it would look odd I think and out of place.
Yes, the basement is insulated.
Here is a VERY ROUGH floor plan.. dont laugh.. lol
Also, I have includd pics of the up and down stairs fireplaces.
Thanks!
ryan
I to have an older house. A lot of square footage and no space. My basement fireplace sits directly below the main floor fireplace. How much open space in in the basement? Mine has 4 small rooms. A stove in there would have cooked you out. The main floor living room is the largest room in the house and where I elected to put the insert.
edit: just seen the pics. I think that you will cook the room in basement before you get any usable heat upstairs. Might be a good place for a small insert in basement and a larger one in the future on the main floor.Another reason I put mine on the main floor is that I'm hardly in the basement. Bunch of teenagers and kids were down there last time I checked. I didn't want a stove where I wasn't as likely to check on it and the kids could mess with it.
Hi Eileen,
Thanks!
ryan
That second FP is screaming for a wood stove, IMHO ;-)
If the basement it is, how easy for the flow to come upstairs and heat the joint?
Hi again,
The only issue I see with the upstairs fireplace is that its raised off the ground, so I would need an insert that has virtually no overhang. The Regency Alterra CI1200/1250 would be one of few options. Any other units similar to this?
It would be difficult for the basement to be fully warmed as you are all saying.. it might be possible, but would for sure make the fireplace room hotter than... lol
Relocating to the main floor might just be a better idea. (and maybe save some extra money on a shorter liner..lol)
Does anyone have any experience with the egency brand?
Thx
Ryan
If you put it in the basement the stove stove is at the far end of the room. It's not impossible to move the heat out of there but I think that room would be cooking hot compared to others. Heat would radiate upstairs but the stairs are at the far end so that would hinder it as well. Doesn't look like you have clearances now in the basement, may have to remove carpet to get the 16" or 18" in front of the stove that you need. As far as it being a dedicated play area. As the kid gets older (toddler) and can be left unattended to play for a while while you cook, take shower whatever you want an area that is as safe as possible. I didn't worry so much about the occasional burn or bump as I did about kids seeing me load the stove and thinking they could do it to or leaving toys and blankets to close to the fire.
The main floor looks like it has tile in front of the fireplace, if so clearance should be good. Depending on the size of your firebox they do make flush mount inserts that would work well.
Have you burned in either fireplace yet? My home just had unlined masonry chimney and the flues were next to each other. With the negative pressure in the basement it would suck smoke down there everytime I lit a fire on the main floor. I ended up blocking the basement flue several years ago which more or less solved the problem (I think there were still cracks in the inner walls of the flue which would draw some smoke smell down because since I have installed an insulated liner and insert I have no issues. Just saying this to prepare you to either raise the main floor flue higher than the other or block the basement flue off. Also you may want to check the basement flue. I know on mine with the fireplaces on top of each other the bottom flue had to make a wicked bend before it could go up along side the other flue. Not sure I could have got a 6" liner around that bend if I wanted to.
That upstairs fireplace needs a Hearthstone Homestead in SeaFoam Green in front of it so bad it hurts!
My stove insert is in my Main living area which is on the back of my house on a slab foundation. The room is 450sqft. there is a door way on either end that leads to the house which is on a crawl space so you go up 3-4 stairs to getinto that part of house. My bedroom is out the far door from stove and into another room then into a hall and down that 15ft so its a good 50ft around and through a door to my bedroom. I can feel the heat in there as well as the other 2 bedrooms that are just outside of the other door to the stove room. My house was originally 1950 built then added onto 2 other times through the years, far from open yet i can heat my home with the stove on all but the coldest days alone. Have not used the heatpump yet this year and we had 2 nights at 20F and highs in the low 40s. I would put a stove on main floor if you can, pellets in the basement (i hate the idea but if you have to haul wood through the home and only use it occassionaly this may be 4 you?) or a very small insert or freestander there?
Does anyone have any experience with the Regency Alterra CI1250/1200 ?
One question I have is this... why do both these inserts have the same specs? yet the 1250 is quite a bit larger than the 1200 in size.
Is the VC Montpelier a good insert?
Any other good flush mount inserts that might be really good in the fireplace pictured above? (the all stone one)
Thanks!
Naaah, blue/black ;-)
Another question i have...
Is there much difference in efficiency ratings of 77% to 85%? Is it just longer burn times? more heat?
or???
Thx
Ryan
Out of say 2 cuft of wood you will get more heat out on the higher efficientcy, obviously. This will mean that you can either get more total heat to heat up faster by running wide open or that you can draft down more on the higher one meaning that 2cuft of wood will last longer than in the lower one as the lower eff one will have to be run on a higher draft to give you the same heat into your room. That said will you notice the difference, maybe or probly not. BUT the 85% one will qualify you for last year tax credit. Whcih dont help you unless they continue the credit this year.
Beamer, can you provide the measurements on your main floor fireplace?
My inclination would be to go with a freestanding stove inserted into that fireplace. I would go with a 2.5 cu. ft up to 3.0 ft. firebox if permitted.
To do this you need to consider if a stove will fit in there (and maybe protrude out onto your hearth shelf), where the flue exit is compared to your venting flue position, and whether you would consider a freestanding unit.
My bias toward that option is because I would avoid a blower if possible. They require electricity to run, they fail and are expensive to replace, and they are unnecessary if the unit throws adequate heat without it. You can use a regular room fan to push air past the fireplace opening and circulate the air for better heating. A stove the size I suggest should be adequate for your home.
I don't think a unit in the basement is going to be worth it for heating more than just the basement. I say start with the upstairs unit and see how it goes.
I have a generator so i dont worry to much about the blower but that is true. My insert protrudes 30-40% into the room and will heat some without it but your not taking full advantage of it without the blower.
I think my fireplace is to small for a freestanding stove. It is only 24" high and 30" wide.
Do not think ?i have seen any that would fit that space??
Now I'm thinking the Alterra 1250 might be to small? It says it only does 1000sqtf max.
Thoughts?
Thanks!
Thoughts?
Thanks!
Might take a look at The Avalon flush wood
Best quote I have gotten for the regency alterra 1250 is $3750.
This includes the unit and complete installation by a WET certified installer, 25ft liner and all taxes.
Does this seem reasonable?
Thx
No idea what the stove costs, but a 25 ft liner kit off Chimney liner depot is a bit less than $400. The install of it alone would be maybe $300 max is what id say it looks pretty easy, gonna do mine this spring. So that leaves the rest for the stove and install of it which should be around $200.
