The Mini shut off a couple of times, with the blinking lights, so I decided to clean the exhaust. I had burned about 3 ton, so it was time. I unbolted the flange, removed a bunch of heat tape and the pipe rotated to a straight position so I could run a brush through it to the outside. When I started the stove back up, house smells of smoke. There is a felt-like gasket that is somewhat the worse for wear. Do I silicone around flange? And then when I need to clean it again, do I just cut away silicone with a razor? Also, I used metal tape to seal back up, but it is not heat rated, this is a problem?
