moisture meters?
I think most of the people on this forum use them. If you put them in straight and pull them out straight, they won't break. I use them for a little while now and I am pretty happy with it. Fairly cheap and gives you a good indication of what wood you have. Measure on the split side of the wood at room temperature.
Remember - procedure counts.
The wood should be above freezing
You should be measuring a newly split face
According to most manuals - you want to stay in the same grain line for both pins. I have tested both with and against the grain with little variation, but that is what most manuals state.
Reactions: Jan Pijpelink
It works for me. All the wood that shows <20% burns real good 20-25% ok but not as much heat from same amount. I do have calibrating block in lab. and ocasionaly check it. Never compared to the one with contact pins.
I thought that pinless ones were not good for firewood?
The cheap box store pinless meters are not good for firewood. The meter that nikolays posted is a professional grade meter intended for use at lumber mills. It is far from a $20-30 meter (nearing the 4 digit price point).
