    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. pistonslap Burning Hunk
    southwestern Pa.
    Has anybody burned mulberry? I got a medium size mulberry that's been down for 2 yrs. from a yard near where I work. I split it 3 mos. ago and it was dry as a bone. It doesn't burn very well or throw a lot of heat. I've had to throw locust in with it to keep the stove up to temp. Has anyone else had this problem or is it just me? It's hard to turn down free wood but I guess I'll pass on it next time.
    #1
    Helpful Sponsor Ads!
  2. Wood Duck Minister of Fire
    Central PA
    I sounds like the Mulberry isn't as dry as you think it is. Mulberry is very dense, high BTU wood, and should burn very well if it is dry.
    Scotty Overkill likes this.
  3. Maple man Member
    i used 2 cords of mulberry last year it put out good heat sounds like yours might not have been seasond long enough.
  4. Thistle Minister of Fire
    Central IA
    Have been burning it off & on for 30 years.Burning a few small chunks right now infact.Climbed up 20 ft this morning & trimmed most of the long dead from the big old tree in back yard.Most hanging over neighbors yard along my fence.
    Great stuff,very similar to Red/Black Oak in density & heat value,not quite as good as White Oak however.Good coals.
    Normally I get a little every year,quite plentiful in the Midwest & most areas east & south of me.Dries in 12-18 months,can be stubborn splitting when its in its usual crooked and/or knotty appearance.
    Backwoods Savage likes this.
  5. JOHN BOY Member
    Western Mountains ,NC
    Mullberry is some great BTU firewood , very dense like others have said. its worth getting ;)
  6. weatherguy Minister of Fire
    Central Mass
    Did you test it with a moisture meter or just going by looks? Looks can be decieving, I found that out after I bought a MM.
  7. geoxman Feeling the Heat
    STL City
    Mulberry is one of my most favorite woods to burn. It burns hot and seasons quick, it is a cousin to Hedge and sparks just like it as well. Happy burning
  8. smokinj Minister of Fire
    Anderson, Indiana
    Mulberry is Sweeet fire wood....Only thing I dont like is it takes a little longer to bust a cord.
  9. blwncrewchief Member
    Northern, IN
    Mulberry as stated above is very good firewood. Real close to locust as far as burning and get it any chance I can. If you are having trouble getting enough heat with mulberry something is wrong with the wood. Mulberry is one of the few woods I will go out of my way to get. Out of the wood around here my desired premium list from top to bottom would be: locust - osage orange (hedge) - mulberry - hickory - sugar maple - oak.
  10. pistonslap Burning Hunk
    southwestern Pa.
    It was on the ground for a couple of years until I split and stacked it. It sure seemed dry, but I must be wrong. Oh well, I'll save the rest til next year. And it was tough to split. Thanks.
  11. Backwoods Savage Minister of Fire
    Michigan
    Pistonslap, being on the ground is the key to why it does not burn well. Now you have it stacked and off the ground, leave it a year and then burn it.
  12. chuckie5fingers Member
    60 S. of Chicago
    if that mulberry isnt cooking you out of the house then it isnt ready.... That stuff burns really hot
    try it next year, I bet it'll be great then...
    chuck
  13. chuckie5fingers Member
    60 S. of Chicago
    it is definately harder to split when dry...
