    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Giles New Member
    N.W. Alabama
    I plan to install gas logs in my fireplace. The fireplace has book shelves, with bottom cabinet, on either side and the cleanest installation would be to drill through the bottom cabinet shelf and exit in the corner of the face and harth brick.
    For a clean look, I would like for the gas shutoff valve to be inside the cabinet. The valve will be approximately three foot from the logs.
    I know different areas have different codes, but as a gerneral rule, would this be ok?
    #1
    Helpful Sponsor Ads!
  2. DAKSY Super Moderator
    It should be fine. Most localities require that the gas
    shut off be within 5 feet of the appliance. You should
    confer with a local gas company for confirmation...
