Hi everyone-
I know this a common request and have read the moderator's advice... but here goes, I'd appreciate any advice.
I've recently purchased a small stone house in western New York. Open space, under 1000 sq ft, loft bedroom, cathedral ceiling.
Early 80's construction skylights and older windows, moderate insulation, big fireplace, not as tight weather wise as I would like. Currently heated with 35000 b.t.u.s propane gravity heater, which is alnost never turned to the highest setting. Half basement is another 400 sq. ft.. Large stone chimney with three races, one for fireplace, one for propane heater and one for this stove. The stove would be in the basement, there are grates allowing air movement upstairs. I'm looking to move to using wood 24/7, I work at home so I think I can take this on.
Local stove company was out and are suggesting an Avalon Ranier. I'm concerned about the burn time, I'd like to load it up at night and have a coal bed in the morning..... The last stove I lived with was an older Vermont Casting that I could stuff full, these new stoves seem very different. So I've thought about upsizing to the Olympic, but would it broil us? Also, have access to the Lopi versions of these.
The other stove I looked at is the Harman Oakwood. Cast Iron, top loading more like the old VC. The stove will be backed up against the base of the stone chimney- would a radiant stove (cast iron) deposit more heat than a convection stove? Any ideas?
I am limited to stove choices not many dealers within range.
