Hey all. I just ordered a Magnum Baby Countryside that will be installed in my garage, which has just been insulated and finished on the inside. The goal is to run with a thermostat and keep garage temp somewhere around 40ish with the ability to warm it up when necessary for work, etc.
Is a direct horizontal vent/straight out the wall install ok for this?
I have enough PL rated exhaust vent to run at least 30" past the exterior of the garage. I'm located in Central Illinois so I don't think altitude is much of an issue. Total length of 3" exhaust will be about 40". I will also add battery backup in case of power outage to prevent smoke backing up inside before I get the generator running.
I had also planned on connected fresh air from the outside.
Also, any tips on how to manage the aluminum siding to install the wall thimble?
