    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Big Donnie Brasco Member
    East Central Kansas
    My wife just HAD TO HAVE an old poorly insulated house, so now instead of running the heating bills through the roof I've decided to get a wood stove.
    I need one with a VERY low wall clearance.
    looking at about 1200 sq ft.
    8-10 hour burn would be nice.
    Not sure that TOO much else matters (log size etc)
    So far with my VERY limited experience, I am considering something like the Pacific Energy Alderlea.
    Which brings up another question.... where am I likely to get the most reasonable price? Like everyone else in this economy we are on a tight budget.
    Thank you SO much for taking the time to listen to all my "new guy" ramblings!
    Sincerely
    Don
    #1
    Helpful Sponsor Ads!
  2. djlarson77 Member
    NW Twin Cities, MN
    Hi Don,
    I don't have a lot of experience with other wood stoves, but I know I'm very happy with my Alderlea T5. We have a 1,700 sf 3-level split, newer windows and well insulated - it heats our entire house no problem - we'll keep our main level around 74 -76 when we're home and it's below 0 outside (stove is on lower level, one-half flight below main). I remember being somewhat obsessed with burn times when I was looking, thinking I could get it going and just forget about it for long periods of time, but that's really not the case, at least for me. It will definitely put out heat for a long time do to the stored energy in the cast iron, but I prefer to add wood more often, before it gets down to end-of-life coals.
    It's not the cheapest stove, especially when we decided we needed to get the fancy majolica brown finish on the outside, but haven't had any regrets on this stove choice whatsoever.
  3. KaptJaq Minister of Fire
    Long Island, NY
    Welcome to the forum...
    To get the best answers the folks here will need a little more information. Some pictures of where the stove will be installed, is it an existing fireplace or will you be building a chase? Layout of the house, etc.
    What are your clearance constraints? That will help define the stove and installation requirements.
    Where are you located? Florida? New York? Alaska? Local climate also plays a part in the planning.
    Good luck.
    ps: Before anybody else says it, you need to start gathering seasoned wood NOW for next season!
    KaptJaq
  4. BrowningBAR Minister of Fire
    Doylestown, PA
    I can relate. Just how poorly insulated are we talking?
  5. Slow1 Minister of Fire
    Eastern MA
    Welcome Don!
    Glad you found this forum - you will get lots of good advice here I'm sure.
    I don't know that stove at all so can't comment much there. However I'm sure others will jump in. There are many great stoves out there and I'm sure you can find one that will meet your needs. As KaptJaq said - do get your fuel figured out quick if you have not already. The main source of problems is generally wood that is not really as dry as it needs to be. Sellers claim 'seasoned' and 'dry' but for a really good experience you will want it to be drier than almost any seller will have (there are exceptions of course, but those are rare!).
    Since you mention wall clearance I'm betting you are not putting this in front of a fireplace or as an insert. Thus I imagine you will be installing a new chimney at the same time - if you haven't already, keep in mind that the cost of a proper chimney can be as much as the stove in your budgeting/planning. Don't try to cut corners there as it is just as important in many ways as the stove to your overall burning experience.
    One other thing to consider - get that home insulated and/or air-sealed. That will pay for itself very quickly. Depending on where you live you may even be able to get it heavily subsidized by your local utility company or such so that it could cost you pennies on the dollar up front.
    Best of luck with your stove decision as well as whatever else you decide! Hope to see you around more...
  6. Big Donnie Brasco Member
    East Central Kansas
    Thank you SO much! I have actually ordered a cord of seasoned wood as of last week :)
    The house is 100 year old lathe and plaster, in East Central Kansas, with poorly fitting windows and doors! :(
    The stove will go where this "dry sink" sits. In the drawing below it would be the RED square.
    [IMG]
    [IMG]
  7. dorkweed Feeling the Heat
    The 57th State
    The stoves with the tightest clearances also come with a premium price tag. Jotul, Pacific Energy, come to mind. You said you were on a budget............. If you can get away with more clearance and are willing to do some fabrication, look at the Englander,30NC or 13NC. These are very economical stoves with great reviews. The drawbacks being clearance and hearth requiremnts.
  8. DanCorcoran Minister of Fire
    Richmond, VA
    You can also put insulated panels with standoffs on the wall behind the stove to reduce clearances, in addition to getting a heat shield on the back of the stove.
  9. Big Donnie Brasco Member
    East Central Kansas
    Unfortunately this room is only 14x14x14x14 so it needs to be as close to the wall as possible.
    There IS a brick chimney right behind the wall where I want to put the stove so I am HOPING to save some $ by utilizing it!.... hoping!
  10. BrowningBAR Minister of Fire
    Doylestown, PA
    Order at least 4 cords.
    You are going to have to oversize quite a bit to compensate. Trust me on this.
  11. MarkinNC Feeling the Heat
    Leicester, NC
    I don't know about the other stoves, but I initially went with the Lopi Endeavor because of it's reduced clearances (4 inches form the wall behind it with double wall pipe). Only ember protection is required below and out front, so you can save a few bucks on the hearth. You'll need to have your chimney lined or a new stove will not work properly. Make sure to run up a few feet before making a turn for better draft.
    If there was a way you could open up that wall between the stove and the chimney, the heat may be more even. I don't know if that is practical or not, just thinking. I heat 1600 SF with mine easily, but the house is tighter than yours by a large margin.
  12. begreen Super Moderator
    South Puget Sound, WA
    It looks like you are going to need a little help with air circulation with that floorplan. Gently blowing cooler air from the kitchen into the stove area will help. FWIW, I endorse your choice. In Kansas with poor insulation, (gotta fix that), an Alderlea T5 is a good fit for this situation. It will provide good long burn times and is easy to run with a partial load of fuel.
  13. James02 Feeling the Heat
    L-Town...N.Y.
    As many will attest to, just because it's advertised as dry get a moisture meter and double check or come time to burn you will be unhapppy!
  14. Wood Duck Minister of Fire
    Central PA
    Most full time burners use at least four cords per winter, and with a big stove and leaky house you might use six. The first year you'll burn more wood than you will in subsequent years due to your inexperience, and possibly also due to wet wood. If you get wood for this year soon you should be able to season it reasonably well by winter; all of Kansas is open, sunny, windy, and dry all summer, right? Of course the complete lack of trees in my mental image of Kansas doesn't bode well for you.
  15. jensent Member
    central Ill
    Lopi Endeaver. Check out the Lopi web site. We have used this stove for 9years with no regrets. Clearances are the best we could find. Used telescoping double wall stove pipe and factory chimney straight up from the stove. That allows us to sweep the chimney without getting on the roof.
    Tom
  16. Big Donnie Brasco Member
    East Central Kansas
    Thank you all so much for the great advice!! You think there is a chance to get it ALL done for < $4,000 ? :)
    Thanks again!
  17. Joful Minister of Fire
    Philadelphia
    If you have a masonry chimney inside that rear wall, perhaps lose the combustable wall board, and give yourself the ability to jam it closer to the rear wall?
    Good quality storm windows on an old traditional single-glazed double-hung window is more efficient than most double-glazed replacement windows, and cheaper by a good margin. So, there's no need to lose the character of your old windows or break the budget in tightening up your house. You can buy or build traditional storms, or get lazy and go with manufactured storms. Either way, you want to tighten that house up where you can, if fuel costs are of any concern to you.
  18. begreen Super Moderator
    The Alderlea is not inexpensive, but it's a good investment. Not sure about Kansas prices, but you are in the ballpark if the stove is $2500 and the chimney + connector comes in at $1500. You will have to see what the local dealers are selling it for. Ask if they have a floor model that they are willing to deal on.
    Will you be making your own hearth pad? If this is a budget breaker then consider putting in a PE Classic or Lopi Endeavor instead. Another close clearance stove that could save you a big chunk of change is the Napoleon 1400.
    http://www.dynamitebuys.com/store/cart.php?m=product_detail&p=872
  19. BrowningBAR Minister of Fire
    Doylestown, PA
    If the home is poorly insulated with bad doors and windows, even though it is a 1400 sq ft home, a T6, Summit, 30NC, Defiant, or any other 3 cu ft stove would probably be the best move if insulation and window/door replacement is not practical at this time.
  20. begreen Super Moderator
    At 1200 sq ft. I'm sure the T5 will handle it. Our next door neighbor has the Spectrum in a 1400 sq ft farmhouse with old windows and poor insulation. It heats the house well even when it's very cold outside. If there is a back up heating system, I would stick with the medium sized PE.
  21. madison Minister of Fire
    In the proposed location, the 14 ft sq room, the hearth pad will have to be circumnavigated when passing thru this room. So besides wall clearances, you should also consider the "livibility" of this obstruction to traffic flow in a 14ft sq room with a stove and hearth.
    Best suggestion would be to pick any stove for starters, download the installation manual, and read it about 4 times, tape an outline on the floor for the required hearth pad, place an appropriate sized cardboard box representing the stove in the taped area, and live with this for a cpl weeks -- while reading more stove installation manuals....
    Big Donnir Brasco likes this.
  22. KaptJaq Minister of Fire
    Long Island, NY
    Is that a closet just to the left of the dry sink? What currently utilizes the chimney, is there an unused flue for the stove? What kind of shape is it in? Has it been inspected?
    As mentioned above, to reduce clearances you can remove the combustibles from the chimney wall. The closet door might also have to be addressed. If the brick is not presentable as it ( and it probably is not) then dress it up with non-combustible stone, tile, or other finish. Look for stoves that only require "ember protection" on the hearth pad. These pads can be very thin. You can cut out the finished floor to the pad size and put a sheet of cement board covered by tile for an ember protection pad. It can be made flush to the floor so it will not create a tripping hazard. If the stove requires thermal protection (R factor > 0) on the pad it will be thicker and probably built up above the floor.
    Most stove manuals are available online. The suggestion to read them and make a cardboard mock-up is a good one. You have a couple of months to finish the install, use the mock-up to see what intrusion on your living space you can deal with first.
    KaptJaq
  23. Cross Cut Saw Feeling the Heat
    We should start a support group.
    After paying stupid money last winter to keep our house barely heated we bought a stove this spring. I'll be able to tell you how it worked out sometime in February, but I think we did good getting a Woodstock Progress Hybrid, they had them marked down $1,000 a couple of months ago...
    If you're really going to do it, get your wood now and stack it.
  24. BrowningBAR Minister of Fire
    Doylestown, PA
    It works. Trust me. I went from 1,500 gallons a winter to using 100 gallons the last two winters combined.
  25. Defiant Minister of Fire
    Old Lyme CT
    Welcome aboard BDBrasco, did you check out pellet stove options yet? Nice house btw:cool:
