NewMac fan limiter
MTP55
2
Michigan
I have an old NewMac wood/fuel oil furnace. the squirrel cage fan will not turn on. I believe the fan limiter thermostat went bad. Does anyone know where to get a new one?
They are available all over the place...just google furnace fan limit switch...pick one that matches your switches dimensions (how far it sticks into the plenum) and temps settings as close as possible. You may be able to find the make/model of yours if you pull the cover off it...
