Northern Minnesota Help
Ash Posted By Ash, Jan 19, 2013 at 2:18 AM
  1. Ash
    Ash
    Burning Hunk 2.
    NULL
    Jan 19, 2013
    157
    53
    Loc:
    Northern Minnesota
    Hi all, longtime reader but first post here. Need some advice on another stove for my 2800 sq ft home. Currently have an isle royale on one end of my L shaped 2800 sq ft home. It keeps the living and dining room where it is on one end of the L plenty warm and the kitchen in the middle of the house also stays in the 70's. Problem is the far living room and the bedrooms which are on the second level above the kitchen/far living room only warm up to around 60 or even low 50's if its in the -10 or -20 degree range like its going to be this wknd. Not warm enough for us especially with a new baby. So while the quad cranks out some serious heat it's time to add another stove. Thinking of a medium sized stove in the far living room. Any opinions on how that might work would be much appreciated. The stairs to the upstairs go up between the far living room and kitchen. Also not sure how or if I can run class A pipe up through the master bedroom to the roof. Thanks
  2. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,851
    8,617
    Loc:
    South Puget Sound, WA
    Welcome ash. Yes you can run class A up through the MBR. It will need to be boxed in a chase, but this is not uncommon. Two stoves in a big house can help.
  3. Ash
    Ash
    Burning Hunk 2.
    NULL
    Jan 19, 2013
    157
    53
    Loc:
    Northern Minnesota
    Thanks begreen. Now the fun starts...narrowing down the search for a new stove.
  4. Lanningjw
    Lanningjw
    Minister of Fire 2.
    NULL
    Oct 15, 2008
    510
    20
    Loc:
    Plymouth, Minnesota
    Good luck Northern MN guy. Jim
  5. KaptJaq
    KaptJaq
    Minister of Fire 2.
    NULL
    Jan 31, 2011
    716
    341
    Loc:
    Long Island, NY
    Is the wall where you are going to put the stove an outside wall? If you don't want to sacrifice living space you can go through the wall and up on the outside of the house. Depending on taste the outside pipe can be either just the bare stainless or you can build a chase around it.
    KaptJaq
  6. Ash
    Ash
    Burning Hunk 2.
    NULL
    Jan 19, 2013
    157
    53
    Loc:
    Northern Minnesota
    Thanks Jim and Jaq. Stove will have to go on an outside wall and do to window spacing and a 9ft window upstairs it will have to go in a corner. Space is not really an issue and also for looks would rather have the pipe inside.
  7. Lanningjw
    Lanningjw
    Minister of Fire 2.
    NULL
    Oct 15, 2008
    510
    20
    Loc:
    Plymouth, Minnesota
    We had a simular problem getting heat thru the living room back to the porch area . I put a 220 base board electric heater in the room and it works great.
    BTW. How cold is it in Northern MN. 5 degrees in the cities at 1230P
  8. jatoxico
    jatoxico
    Minister of Fire 2.
    NULL
    Aug 8, 2011
    3,167
    958
    Loc:
    Long Island NY
    While your figuring out what you want to do, have you tried using a fan to blow the cooler air into the heated rooms? Many people have to do this to even the temps in thier house out.
  9. Ash
    Ash
    Burning Hunk 2.
    NULL
    Jan 19, 2013
    157
    53
    Loc:
    Northern Minnesota
    Have used fans before but they only bump up the temp a couple of degrees so not quite enough. Jim, -8 at 5:30pm here and supposed to be 27 below by morning so it'll be a bit chilly here tonite.
  10. ClanCameron
    ClanCameron
    Member 2.
    NULL
    Dec 17, 2012
    70
    19
    Loc:
    South Central Minnesota
    Yup that's cold. I'll quit my whining.
  11. miket
    miket
    New Member 2.
    NULL
    Jan 20, 2013
    1
    0
