OAK Kit length
stallau
90
Southern ME
My stove is in the basement and as such there's a good height difference to get from above the sill plate to the stove. Would it matter if I extended the air intake hose (thinking about power of motor to pull air over the distance) and since the ones that come with kits are usually about 6 ft what would be recommended to use for a replacement hose?
Thanks
Piece of pipe and cut the flex in half and get a couple of hose clamps, and maybe a can of paint for the pipe. Your over thinking the issue :)
check manufacturer specs, with our stoves when a long OAK is used we recommend bumping up from 2 inch to 3 inch due to the added length. depending on what unit you have the manufacturer may or may not require a larger diameter for longer runs.
My oak kit goes up my flue 1.5 stories... no problems. as above, if you go longer, you might want to go wider too.
